exploded transfercase - JeepForum.com
post #1 of 67 Old 12-03-2012, 07:06 PM Thread Starter
iser
iser's Avatar
i literally exploded it. pics to come.
what the heck would cause this? i'm so heartbroken right now. i was parked, and when i try to drive away, the wheels were locked up. gave it a hard rev and CRACKSMASHBOOMBANG the transfercase was done.
*sigh* what would cause this? good thing i have a spare transfercase laying around. i just don't have the time to install it.
- REST IN PEACE, RATMONKEY -
Specs- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
Upcoming Projects- Front Axle Swap. On the look out for HP30.
_______________________________________________
"lead me, follow me or get the hell out of my way"
- gen. george patton
iser is offline
post #2 of 67 Old 12-03-2012, 07:13 PM
RagTagSoldier
dude the past couple of months for you and your jeep have sucked lol. sorry to hear. eager to see the pics lol
RagTagSoldier is offline
post #3 of 67 Old 12-03-2012, 07:16 PM
Scopez
1994 ZJ
Damn bro! Maybe stretched chain? I don't even know bro.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #4 of 67 Old 12-03-2012, 10:44 PM
ZJMTL
Talk about terrible luck...
'96 Laredo Build Thread - https://www.jeepforum.com/forum/f197/zjmtls-project-thread-daily-driver-weekend-getaway-vehicle-1360544/
ZJMTL is offline
post #5 of 67 Old 12-03-2012, 10:55 PM
Jeep318
Ouch sorry to hear that post pics of the carnage. Did it just go or did you have any leaking or binding or noises prior to the explosion?
Jeep318 is offline
post #6 of 67 Old 12-03-2012, 10:56 PM
Uniblurb
Uniblurb's Avatar
Bummer iser and what else can happen!
When my 242 went out the top rubber plug popped out blowing all the fluid out before I even knew it. But it didn't explode and the parts just ground up in there while it started making noise. It did loosen/stretch the chain and you could see where it was hitting the inside of the case.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #7 of 67 Old 12-04-2012, 06:13 AM
FAlfani81
Did something freeze in it? You do live in an arctic tundra
FAlfani81 is offline
post #8 of 67 Old 12-04-2012, 07:27 AM
zarnold
Yeah, real bummer. Didn't you swap this one in not to long ago?
86 CJ-7, 258 Engine, T-177, Dana 300, Dana 30, AMC 20
zarnold is offline
post #9 of 67 Old 12-04-2012, 08:27 AM
LordBhael
LordBhael's Avatar
That's a toughy. Sounds to me like the rear axle, or something between the axle and the later half of the main shaft inside the t-case was bound up somehow, and the main shaft inside grenaded. Don't know if you had it in 4wd, but the weak point between the front axle and the t-case, at least for me, was the chain inside the t-case. I followed some bad advice, and jacked that up pretty good, but it didn't damage the case enough to cause a leak. I pulled the front driveshaft, and ran it in 2wd just fine. But that was also a different t-case in the family, so it may very well be different. On that one, I'd have thought something in the rear driveshaft assembly would have gone first, like the u-joints, before the shaft.
Yup, I'm gonna go with some kind of binding in the tailshaft, or maybe failed bearing inside the case.
There's never time to do it right, but there's always time to do it over.
LordBhael is offline
post #10 of 67 Old 12-04-2012, 09:02 AM
Uniblurb
Uniblurb's Avatar
Good point and I was wondering the same thing since saw where he was broke down at -40 below just recently.
https://www.jeepforum.com/forum/f13/o...l#post14545024
Uniblurb is offline
post #11 of 67 Old 12-04-2012, 09:03 AM
cootertwo
1997 XJ Cherokee
pictures pictures pictures.....................
cootertwo is offline
post #12 of 67 Old 12-04-2012, 09:06 AM
nicklopic
Iser... you have an awesome jeep but terrible luck with it
I really want to know how that could have happened
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #13 of 67 Old 12-04-2012, 09:54 AM
LordBhael
LordBhael's Avatar
Wouldn't it have to get warm enough to thaw our first, then refreeze, though? Again, not being ignorant, just wondering. I don't see where the t-case would warm up enough to liquify water, unless he garaged it somewhere warm for a while. That would make sense, though. Warm water, freezing inside the t-case would crack the housing, when we went to drive, it might bind up a bit from the internals being misaligned, then blow the thing apart when he gunned it a bit.
post #14 of 67 Old 12-04-2012, 03:58 PM
Foundrydude
What locked the wheels? Ice or mechanical issues in the axle?
The chain probably let go spectacularly.
Mine is probably gonna do the same, soon. Was pulling a post with it last weekend and when it hits the end of the chain there's a clicky sound coming from inside the case like a chain slipping......
Correspondingly, I do not like reading this thread
good luck with the truck
Foundrydude is offline
post #15 of 67 Old 12-04-2012, 05:56 PM Thread Starter
iser
iser's Avatar
i have a feeling there was water inside and it froze. that's the only explanation i have. i'm so frustrated since i just swapped this tcase in. i'm pretty close to saying i'm done with this jeep even though i love it so much. i need a reliable dd. it's -40. i can't be worried about my vehicle, wondering what will grenade next.
*sigh*
iser is offline
