exhaust manifold leaking? with video - JeepForum.com
 1Likes
  • 1 Post By Timo_90xj
post #1 of 8 Old 10-15-2021, 02:05 AM Thread Starter
Mark-318-IT
5.9 started to make this "blowing" noise a few days ago. it follows the revs, goes up and down as the rpms go up and down.
over, let's say, 2k rpms it stops...or i think it stops because the engine get's louder and i can't hear it anymore.
exhaust manifold was pretty lose, 2 nuts could literally be turned by with zero effort with a wrench.
tightened all up, but got zero result on the noise.
engine oil is perfect.
3k miles on the engine.
what do you think?
360swapped:np242swap,shift kit,BOLT ONs,ome HD coils,aussie locker,dana30hp trussed
Mark-318-IT is offline
post #2 of 8 Old 10-15-2021, 04:14 AM
Timo_90xj
Timo_90xj's Avatar
Which exhaust gaskets did you use? The crappier ones don't last anyways in the long run, and they fail in an instant if you have a leak.
***Under construction***
Timo_90xj is offline
post #3 of 8 Old 10-15-2021, 04:25 AM Thread Starter
Mark-318-IT
if i remember correctly, they are some ebay "engine tech"
post #4 of 8 Old 10-15-2021, 05:35 PM
Jeepy95
I wouldn't trust EBay engine tech gasket get felpro instead think there OEM gaskets
Jeepy95 is offline
post #5 of 8 Old 10-15-2021, 06:10 PM
Timo_90xj
Timo_90xj's Avatar
Remflex:
https://www.summitracing.com/search/...l-block-magnum
HighLonesome likes this.
post #6 of 8 Old 10-16-2021, 01:44 AM Thread Starter
Mark-318-IT
thanks guys,
so it looks like my cheap-o ebay ones didn't last long.
i'll buy the new ones.
how bad is it to run with a leaking exhaust manifold gaskets?
post #7 of 8 Old 10-16-2021, 01:06 PM
GOLDWING
GOLDWING's Avatar
thanks guys,
It will definitely send erroneous inputs to the o2 sensors at the least. Over time, I would expect damage to the manifolds or heads from erosion. YMMV!
"The Dude Abides"
"Your axles are going to turn into spaghetti noodles."
Polka Power 1/3/2021
GOLDWING is offline
post #8 of 8 Old 10-18-2021, 01:58 AM Thread Starter
Mark-318-IT
thanks, i'll buy the new ones then.
