exhaust manifold /headers and y-pipe options - JeepForum.com
 5Likes
post #1 of 16 Old 10-25-2021, 07:12 AM Thread Starter
Mark-318-IT
Hi guys,
i need to change my exhaust manifold gaskets because i have a leak on the passenger side.
since i need to take the manifolds off the block, can i mod them somehow?
i think doug thorleys are the only headers option that won't need any notching, but they are simply too expensive for me.
92 / 93 360 (also 318?) had bigger manifolds, but what exactly am i looking for? ram trucks? vans?
also, what about the crushed section of the y-pipe? what's the best bang for the buck? do it myself ? any aftermarket options?
thanks
360swapped:np242swap,shift kit,BOLT ONs,ome HD coils,aussie locker,dana30hp trussed
Mark-318-IT is offline
post #2 of 16 Old 10-25-2021, 11:46 AM
HighLonesome
HighLonesome's Avatar
If you're after the 2 1/8" outlet exhaust manifolds, you want the ones with last 3 digits #618 and #619 which are on the early Dakotas and Rams ('92/93).
https://www.forabodiesonly.com/mopar...ifolds.492689/
Mark-318-IT likes this.
HighLonesome is offline
post #3 of 16 Old 10-25-2021, 05:55 PM
PolkaPower
PolkaPower's Avatar
Originally Posted by Mark-318-IT View Post
Hi guys,
https://www.youtube.com/watch?v=2dJDu8K-91o
thanks
Replacing the crushed section on the passenger down pipe will probably be the best gain without new headers. I've not heard of 93s having larger or better flowing headers and that seems like a waste of time.
Anything besides Thorleys is going to need a bit of modification to work.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #4 of 16 Old 10-25-2021, 07:48 PM
jm8881
My 96 came with 2 1/8" manifolds. Not sure about my 98. I put doug thorlies on my 96 and they were worth every single cent. That being said I see they are over $1100 now. When i bought them they were around 800.
I don't know what quality these are but I seen them on ebay and they weren't an option back when I had my 96.
HighLonesome and Mark-318-IT like this.
jm8881 is offline
post #5 of 16 Old 10-26-2021, 07:31 AM Thread Starter
Mark-318-IT
thanks guys for the tips.
keep in mind that i'm interested in this just because i need to remove the ex manifolds in order to replace gaskets.
the overall idea is bigger manifolds and y-pipe.
also, keep in mind that i can not run headers because i won't be able to pass inspection. i need something "factory looking".
any tips on that y-pipe?
post #6 of 16 Old 10-26-2021, 10:49 AM
HighLonesome
After a little reading, it seems the big outlet manifolds were used on '96-98 GCs. And '92/93 Durangos and Vans too. So Mark, you may already have what you want.
What some have done on various vehicles is hog out the manifold outlets to 2 1/4" and then run a dual 2 1/4" or 2 1/2" exhaust. Or do a custom y-pipe joining 2 1/4" or 2 1/2" downpipes to a single 3" pipe.
post #7 of 16 Old 10-27-2021, 02:30 AM Thread Starter
Mark-318-IT
hi Andy, that's an interesting point.
what does hogging the manifold mean? like boring the outlet?
before purchasing anything i'll measure mines in order to be sure.
thanks
post #8 of 16 Old 10-27-2021, 08:11 AM
HighLonesome
thanks
yes
good luck
post #9 of 16 Old 11-02-2021, 08:12 AM Thread Starter
Mark-318-IT
hey guys,
took some measurements
looks like i already have 2 and 1/8" manifolds.
at this point, are 92/93 bigger (like 2 1/4)? am i missing something here?
attaching pics
post #10 of 16 Old 11-02-2021, 09:48 AM
HighLonesome
Sweet! every once in awhile the Jeep gods send a gift.
What are those casting numbers? I can't see from the pic.
From reading, I think the early and late castings are all 2 1/8".
post #11 of 16 Old 11-23-2021, 02:22 AM Thread Starter
Mark-318-IT
hey guys,
yesterday night i took down the driver side exhaust manifold.
here's pics of the gasket, what do you think? definitely leaking ?
WhatsApp Image 2021-11-23 at 09.05.39.jpg   WhatsApp Image 2021-11-23 at 09.05.38.jpg
post #12 of 16 Old 11-23-2021, 02:42 AM
Timo_90xj
Timo_90xj's Avatar
Yeap, it was leaking.
zjosh93 likes this.
***Under construction***
Timo_90xj is offline
post #13 of 16 Old 11-26-2021, 04:27 AM Thread Starter
Mark-318-IT
started to port a lil bit the outlet on the driver side manifold. not sure if it will help or not lol.
post #14 of 16 Old 11-30-2021, 01:43 AM Thread Starter
Mark-318-IT
damn, removing the manifolds was super easy (probably because the engine has like 4k km on it), removing the y-pipi from the cat/cat back section is a nightmare...
at this point, since the whole exhaust system will be off, i'll try to attach a second exit on other side of the rear bumper.
post #15 of 16 Old Today, 03:37 AM Thread Starter
Mark-318-IT
i trying to enlarge the crushed section by heating the pipe up and hammering down another pipe into it. i'm down a lil more than 2 inches now, about half way.
i'm no good at welding.
