Drivers door speaker is badly distorted. - JeepForum.com
post #1 of 10 Old 09-20-2020, 05:03 PM Thread Starter
Rapidrob
Rapidrob's Avatar
Sound is badly distorted. I removed the speaker and the speaker cone if fine. It was tight in the mounting frame.
Is the speaker "blown" or is it a problem with the radio/amplifier.
If I use the joy stick to select the Rear speakers the Left channel is not distorted.
Only the Left Front speaker is distorted. ( it sounds like a blown speaker, if you know what that sounds like.)
The FAC's do not have this in the archives.
Rapidrob is offline
post #2 of 10 Old 09-20-2020, 05:39 PM
hilljacknm
All the speakers were blown out on my '96. Would not doubt yours are heading south also.
1996 ZJ 5.2
Doug Thorley Headers, Kolak exhaust
B&M 70268 trans cooler
BFG KM3 30x9.50"
hilljacknm is offline
post #3 of 10 Old 09-20-2020, 05:47 PM Thread Starter
Rapidrob
Rapidrob's Avatar
What did you replace them with?
Rapidrob is offline
post #4 of 10 Old 09-20-2020, 06:10 PM
hilljacknm
I went with pretty much a factory replacement.
Infinity REF-6522EX Shallow-Mount 6-1/2 Inch Coaxial Car Speakers .
Some adaptor/connectors make for an easy install.
Metra 72-1002 Speaker Connectors for Jeep and Eagle Vehicles
There may be better options out there, but these are good enough for my ears.
1996 ZJ 5.2
BFG KM3 30x9.50"
post #5 of 10 Old 09-21-2020, 02:21 AM
riiz
riiz's Avatar
I replaced all 4 speakers with Rockford Fosgate R165X3. I purchased them from crutchfield, which supplies the adpators at no cost, all for $97 shipped to your door. I couldnt believe how much I cared about audio till I started driving my jeep on hour long road trips.
riiz is offline
post #6 of 10 Old 09-21-2020, 06:33 AM Thread Starter
Rapidrob
Rapidrob's Avatar
Thanks guys for the info, I do appreciate it.
Rapidrob is offline
post #7 of 10 Old 09-21-2020, 11:19 AM
itisskyler
I second this recommendation. I did my front with these, will do the back later.
Only downside is the gray liner inside the door is old, brittle, and crumbled away once I removed the panel. I haven't found a replacement for that yet, not even sure if it is necessary, but they put it there for a reason.
itisskyler is offline
post #8 of 10 Old 09-21-2020, 04:03 PM Thread Starter
Rapidrob
Rapidrob's Avatar
to prevent Water dripping on the paper cone in heavy rains or car wash.
Rapidrob is offline
post #9 of 10 Old 09-21-2020, 09:45 PM
itisskyler
I was referencing the gray liner between underneath the inside door panel when you remove it to replace the speaker. Mine disintegrated.
The speaker cover is intact
post #10 of 10 Old 09-22-2020, 10:38 AM Thread Starter
Rapidrob
Rapidrob's Avatar
Yep, mine is like a Graham Crackers. You touch it and it just crumbles. Lowest Bidder on that part.
Rapidrob is offline
