Door hinge pin suggestions - JeepForum.com
 2Likes
post #1 of 33 Old 03-08-2019, 09:43 AM Thread Starter
Xpress
Xpress's Avatar
I replaced my drivers door hinge pins about 3 years ago with a doorman kit, but it has since failed and now I'm looking for a more permanent solution to this issue. I can't seem to find anything on the web that isn't doorman, does anyone have any suggestions for a good heavy duty kit?
All about that unibody life.
'96 ZJ 5.2L, IRO 3.5" lift, KOR radiator support, MVF steering brace
Xpress is offline
post #2 of 33 Old 03-08-2019, 10:46 AM
zjosh93
This is the kit that everyone recommends: https://www.ebay.com/itm/USA-MADE-De...ss!78753!US!-1
I bought one and it looks great. Haven't put it in yet but others have on here.
zjosh93 is offline
post #3 of 33 Old 03-08-2019, 11:46 AM
kg6mov
Hears the voices
kg6mov's Avatar
The dorman bushings don’t last, so they’re generally not worth bothering with. The best options are either the mopar pins and bushings, or the ebay kit zjosh linked above. I’ve done both and they’ve held up great.
kg6mov is offline
post #4 of 33 Old 03-08-2019, 12:05 PM
jeepjeepster
Installed these a few months ago after the dorman unit failed. Dont remember paying that much (maybe I did??) and cant speak of their longevity since its not been very long..
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #5 of 33 Old 03-08-2019, 12:53 PM Thread Starter
Xpress
Xpress's Avatar
Thanks fellas, I went with the ebay ones.
Xpress is offline
post #6 of 33 Old 03-09-2019, 08:22 AM
Billyjoebob007
Are there any bushings avail for the Door Body Half HINGES ? That supposed to be one solid unit ? #7
Billyjoebob007 is offline
post #7 of 33 Old 03-09-2019, 11:48 AM
muddflow
I found some pins for a Grand Cherokee door hinge pins from Red Hound. I'm un certain how the quality compares but appears similar to the TAI 9020215 (~$45.00 each) They also use nuts same as the TAI pins.
http://redhoundauto.com/category/hinge-pins.html
http://www.redhoundauto.com/fit/740013.html
Below is a link to what appear to be the same hinges as sold on eBay. I believe these to be TAI pins (Total Automotive)
https://totalauto.com/hingelookup/hi...ee&Body=4+Door
https://totalauto.com/pr/MRHK12/664286
muddflow is offline
post #8 of 33 Old 03-09-2019, 03:59 PM
scodo1968
just replaced mine. Hardest part was grinding the factory out. Easy fix.
1997 grand cherokee limited v8
1999 grand cherokee limited
1997 grand cherokee larado
scodo1968 is offline
post #9 of 33 Old 03-09-2019, 04:23 PM
muddflow
I'm going to attempt to either cut out with a small saw or try using my oxygen propane torch with a fine tip.
I think some people were able to cut the bolt in half then cut it even shorter so it can be pulled out from one end.
However I don't want to burn the paint using a torch, with additional protection possibly can use a torch. Otherwise I have a dremel that uses small steel round saw blades.
I wrote to Red Hound Auto asking them about the quality of their hinge pins.
My passenger door as well as the other door hinges appears to be ok.
muddflow is offline
post #10 of 33 Old 03-09-2019, 04:28 PM
kg6mov
Hears the voices
kg6mov's Avatar
I use a dremel when I cut them out, isn't too bad. A cut off wheel on a die grinder would be really tops.
3hounds likes this.
kg6mov is offline
post #11 of 33 Old 03-10-2019, 10:35 AM Thread Starter
Xpress
Xpress's Avatar
I used a dremel with a cutoff wheel. Took a couple minutes but it cut the pin right off.
3hounds likes this.
Xpress is offline
post #12 of 33 Old 03-10-2019, 06:04 PM
muddflow
I found Mopar pin kit p/n 55074591 for my 95 ZJ. Crosses to the OEM p/n found in a Jeep 94-96 OEM parts manual.
DOOR, FRONT SHELL AND HINGES ZJ, ZG BODY
5507 4591 4 BUSHING, Hinge Pin
This is an adequate quality pin kit, as good as the TAI - MRHK12 or the pin kit from the eBay link below?
muddflow is offline
post #13 of 33 Old 03-11-2019, 01:02 PM
muddflow
No one responded to my question about the quality of oem hinge pins. My assumption they must be better quality than the less expensive aftermarkets.
I'm uncertain how they compare to the TAI stainless pins with threaded ends and nuts.
My current ones installed appear to be original factory OEMs with 227,000 miles where only the drivers side has just started to become loose.
While looking on RockAuto under my 95 ZJ no Mopar oem pins are shown. However after looking in an OEM Jeep Parts Manual finding the hinge pin part number, performing a part number search on RockAuto turned up a Mopar pin set.
OEM part number for a 95 ZJ is 55074591
There is no "application" information so I'm uncertain year date range for the ZJ other than a reference to p/n 55074591 for years 1994 - 1998.
Apparently a pin kit is one pin with bushings? from RockAuto are purchased as a set of four when placed into the shopping cart.
Which I assume is four pins with bushings for both front doors.
$5.74 each x 4 pin sets = $22.96, with shipping, tax & 5% discount total = $27.24
A few months ago previously ordered were the Dormans, that haven't been installed. After further reading online, I was going to order one set of the TAI pins for the driver's door but after finding the Mopars decided to order them instead.
If the quality of the TAI's is approx. the same as Mopars and the only difference is the threads with nuts, cost wise the Mopars are a better deal.
TAI - MRHK12 pin is listed on Amazon for $37.95 with free shipping for one pin set.
https://www.amazon.com/National-Part...MGK6F7ECFD9CG1
and on the TAI site for $34.95 + $7.95 shipping = $42.90
Cost of 4 pin set = $75.90 & $85.80
I've read that the TAI bushings are 680 Bronze, oil impregnated
muddflow is offline
post #14 of 33 Old 03-11-2019, 01:25 PM
zjosh93
Just a thought - IMS the upper pin can't be installed from above. The Mopar pin would need to be installed from below. The only thing keeping them in at that point is the knurl on the pin. I wouldn't trust that. Would be a good idea to figure out a way to secure the top; the ebay ones use the nylock nuts, and I've seen some (not for the ZJ) that use a cotter pin or E-clip. Like I said, just a thought, you pays your money and you takes your chances.
zjosh93 is offline
post #15 of 33 Old 03-11-2019, 03:20 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yeah, the mopar pin expects you to be able to flatten the top with an airchisel.
The knurl is actually pretty reasonable for retaining the pin, never had a problem on my niner.
The mopar bushings are very nice, they’re a stamped steel part with a teflon like coating on the inside.
I did the mopar on my niner: https://www.jeepforum.com/forum/f13/...l#post19914065
And the total automotive on my green pig: https://www.jeepforum.com/forum/f13/...l#post38467962
kg6mov is offline
Relay Wiring Help Pishotta Audio, CB & Ham Radios, GPS, & Electrical 7 02-25-2019 02:38 PM
258 build suggestions McSyd Engines & Drivetrain 19 02-17-2019 07:30 PM
dana 35 carrier center pin problem gerrymurphy YJ Wrangler Technical Forum 7 01-20-2019 05:04 PM
95 ZJ nothing when ignition key turned to start muddflow ZJ Grand Cherokee Forum 41 11-16-2018 02:02 PM
Dash wire help kryton WK Grand Cherokee & XK Commander Forum 11 06-19-2018 06:43 AM
