Doing plenum gasket... what else to do? - JeepForum.com
 4Likes
  • 1 Post By Maverickxeo
  • 1 Post By PolkaPower
  • 1 Post By Zilliver
post #1 of 6 Old 05-27-2020, 11:39 PM Thread Starter
Maverickxeo
Maverickxeo's Avatar
I looked into my intake and saw pooling oil - so I ordered the Hughes plenum kit.
My 5.2L has 360k km on it... is there anything else I should look at doing while I'm in there? I'm going to inspect the pushrods and lifters (other than physical damage, is there anyway to tell if they are damaged or worn?). Are valve seals any easier to do at this time? Would it make sense to do them?
LittleFootZJ likes this.
Maverickxeo is offline
post #2 of 6 Old 05-28-2020, 05:10 PM
PolkaPower
PolkaPower's Avatar
Valve cover gaskets, inspect timing chain cover for small leak below. It's a common gasket failure. Not a bad idea to replace the timing chain. Inspect water pump for leak at the weep hole underneath.
Tune up if it's been awhile. Coolant flush with new hoses if needed. Any hard to reach things like the crank sensor is up to your discretion for preventative maintenance.
Add oil catch can on the pvc return line.
Sent from my BND-L24 using Tapatalk
PolkaPower is offline
post #3 of 6 Old 05-28-2020, 10:44 PM
LittleFootZJ
I have the intake off and I am literally doing all of the above
Sent from my iPhone using Tapatalk
LittleFootZJ is offline
post #4 of 6 Old 05-29-2020, 04:47 AM
V8GCZJ
It's a lot easier to do a cap/rotor maybe wires also.
V8GCZJ is offline
post #5 of 6 Old 05-29-2020, 01:51 PM Thread Starter
Maverickxeo
It's kinda funny... but I did a lot of that within the last few years, haha! I'll inspect it all though to make sure.
PolkaPower likes this.
post #6 of 6 Old 06-01-2020, 12:53 AM
Zilliver
Watch the oil sensor, if its leaking, then good access to replace.
98 Grand Cherokee 5.9 - daily
95 Grand Cherokee 5.2 - offroad
Zilliver is offline
