Does this steering geometry seem ok? - JeepForum.com
post #1 of 14 Old 01-11-2020, 01:16 PM Thread Starter
jcjunkie
jcjunkie's Avatar
I bought this jeep lifted the way it is. I need a few guys inputs on is the geometry look ok? And also is this a drop pitman arm or regular?
And lastly my rear driveshaft angle, it seems odd, like the rear end needs pitched more towards tcase. I don't feel any vibration though.
IMG_20200111_141002564_1578770168056.jpg   IMG_20200111_140956792_1578770176457.jpg   IMG_20200111_140543571_1578770190811.jpg
98 5.9
jcjunkie is offline
post #2 of 14 Old 01-11-2020, 01:17 PM Thread Starter
jcjunkie
jcjunkie's Avatar
IMG_20200111_140551069_1578770230876.jpg   IMG_20200111_140527889_1578770240134.jpg
98 5.9
jcjunkie is offline
post #3 of 14 Old 01-11-2020, 01:25 PM
BigDaveZJ
On that type of rear driveshaft, the output of the t-case and the yoke on the axle should be parallel to each other, hard to tell from pics but it looks close. If it had a double cardan at the t-case (like your front driveshaft should) then you would want the rear diff to point directly at the output of the t-case.
Hard to tell if the pitman arm is a drop arm or not, looks like it could be but if it is there isn't a lot of drop in it. The angles look okay to me.
95 ZJ with lots of stuff
98 5.9
15 JKUR on 35's
BigDaveZJ is offline
post #4 of 14 Old 01-11-2020, 01:50 PM
CatSplat
CatSplat's Avatar
1994 ZJ
Angles look OK to my eye. That janky double stabilizer setup worries me more.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 33" Cooper Discoverer STT Pro
The Jeep of Theseus
CatSplat is offline
post #5 of 14 Old 01-11-2020, 03:16 PM Thread Starter
jcjunkie
jcjunkie's Avatar
I thought it looked kind of odd to with two stabilizers that looks like some sort of welded up Fab I may end up trying to remove
98 5.9
jcjunkie is offline
post #6 of 14 Old 01-11-2020, 07:41 PM
CatSplat
CatSplat's Avatar
1994 ZJ
My major concern is the double-stab may have been put in to cover up some death wobble, but I'm sure you'll find out whether that's true or not!
The Jeep of Theseus
CatSplat is offline
post #7 of 14 Old 01-12-2020, 09:55 AM Thread Starter
jcjunkie
jcjunkie's Avatar
No death wobble but it does have some moderate bump steer...
98 5.9
jcjunkie is offline
post #8 of 14 Old 01-12-2020, 11:44 AM
kg6mov
Hears the voices
kg6mov's Avatar
It looks like you may have a drop pitman arm, that would cause some bumpsteer. Hard to tell without a good front picture that gets all four drag link and track bar mount points.
kg6mov is offline
post #9 of 14 Old 01-12-2020, 12:01 PM Thread Starter
jcjunkie
jcjunkie's Avatar
Ok I can supply that later. It's my understanding a drop pitman arm is needed over 4" to help bump steer?
Your saying it causes it?
98 5.9
jcjunkie is offline
post #10 of 14 Old 01-12-2020, 12:33 PM
kg6mov
Hears the voices
kg6mov's Avatar
Changing the position of the drag link mount without changing the position of the track bar mount will cause bumpsteer.
Over 4" you have poor angles with stock mount points, but you can still get acceptable steering with the stock pitman arm.
kg6mov is offline
post #11 of 14 Old 01-12-2020, 01:16 PM Thread Starter
jcjunkie
jcjunkie's Avatar
Alright. So I mount my track bar differently or get a stock pitman arm?
What is the best alternative for this to get all aligned perfectly?
Thank you.
98 5.9
jcjunkie is offline
post #12 of 14 Old 01-13-2020, 04:32 PM Thread Starter
jcjunkie
jcjunkie's Avatar
Here's a better angle...
IMG_20200113_173058216_1578954743213.jpg   IMG_20200113_173002734_1578954752404.jpg   IMG_20200113_173832350_1578955222681.jpg   IMG_20200113_173758170_1578955231388.jpg
98 5.9
jcjunkie is offline
post #13 of 14 Old 01-14-2020, 02:35 PM
Timo_90xj
Timo_90xj's Avatar
We need a picture taken from the front showing the full width of steering linkage & trackbar in a single shot - not detailed close-ups from weird angles.
Here's an example:
***Under construction***
Timo_90xj is offline
post #14 of 14 Old 01-15-2020, 04:08 PM Thread Starter
jcjunkie
jcjunkie's Avatar
Here
jcjunkie is offline
