Does the downstream O2 Sensor affect fuel/air mixture? (5.2, 1997) - JeepForum.com
 3Likes
  • 1 Post By zjosh93
  • 1 Post By Timo_90xj
  • 1 Post By kg6mov
post #1 of 14 Old 08-13-2020, 07:57 AM Thread Starter
demagogue
demagogue's Avatar
I have a '97 ZJ with the 5.2. Some jerk thief stole my cat, cutting my exhaust with a sawzall, cutting the downstream O2 sensor wire. I've driven the jeep a little bit (< 10 miles, sounds AWFUL) but I was expecting it to throw a code or something.
My question is, am I going to be running extremely rich or anything? Does the downstream sensor do anything other than throw a code in the event of a missing/bad cat? I'm also a little bit perplexed on why I haven't seen a code yet.
I have a new Y pipe/OE cat/catback exhaust on the way but it won't be here for awhile and I will need to drive the ZJ some in the meantime. I just want to make sure I won't be damaging the engine.
2002 KJ (Owned 2005-2015, RIP)
1997 ZJ Limited
2013 Subaru BRZ Limited
1974 Ford F-100
demagogue is offline
post #2 of 14 Old 08-13-2020, 08:53 AM
kg6mov
Hears the voices
kg6mov's Avatar
No
kg6mov is online now
post #3 of 14 Old 08-13-2020, 11:41 AM
CatSplat
CatSplat's Avatar
1994 ZJ
Nope, D/S sensor is only used to check cat efficiency.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 33" Cooper Discoverer STT Pro
The Jeep of Theseus
CatSplat is offline
post #4 of 14 Old 08-13-2020, 12:39 PM Thread Starter
demagogue
demagogue's Avatar
Thanks!
Still surprised I'm not seeing a check engine. Maybe something else is broken. /shrug
1997 ZJ Limited
1974 Ford F-100
post #5 of 14 Old 08-13-2020, 01:18 PM
zjosh93
Not 100% certain on the ZJ what conditions are required for the PCM to check the downstream sensor. On most cars it's a specific set of driving conditions, like more than 10 minutes driving above 50 mph with the coolant temp above 180 degrees. Or something like that. If you keep making short trips it might not ever see the right conditions.
Mark-318-IT likes this.
zjosh93 is offline
post #6 of 14 Old 08-13-2020, 02:36 PM
Timo_90xj
Timo_90xj's Avatar
In short: JTEC PCMs actually do monitor and slightly adjust A/F ratio based on the downstream sensor as well.
I have a SBEC/JTEC/NGC- booklet as a PDF, and in the O2- sensor segment it mentions that starting in 1996 (OBD2), JTEC- based PCMs use downstream O2- sensors for two things:
1. Monitoring cat converter efficiency by comparing switching rates of upstream and downstream O2- sensors. PCM will store a fault code for cat converter efficiency if switching ratio exceeds a calibrated value.
2. Downstream fuel control = Downstream sensor signal causes PCM to adjust upstream O2- sensor goal voltage. Raising the goal voltage to reduce high O2- content increases overall fuel (= slightly longer pulse width), and lowering the voltage to increase low O2 content by leaning out the mixture.
The effect of the downstream sensor isn't huge, if I'm understanding the graphs in the PDF correctly, it's in the region of around +/- 0.10 volts. O2 sensor voltage varies between ~0.0 volt to ~1.0 volts so we're talking of about +/-10% difference in goal voltage for upstream sensor.
Kolak likes this.
***Under construction***
Timo_90xj is offline
post #7 of 14 Old 08-13-2020, 02:38 PM
kg6mov
Hears the voices
kg6mov's Avatar
I'd expect you to at least be getting a downstream 02 sensor heater failure code, since the heater is, uh, missing. As mentioned the actual converter malfunction code may not pop up if you don't have the engine in the right state for long enough.
Also note that the heater and sense lines for the 02 sensors are notorious for frying the PCM if they short in the wrong way, make sure the wires are taped up until you can get things replaced.
Timo_90xj likes this.
post #8 of 14 Old 08-13-2020, 08:56 PM
jeepjeepster
Just dont let those wires short out. Can you get to the plug and just unplug them?
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #9 of 14 Old 08-14-2020, 12:53 AM
Kolak
Vendor
Kolak's Avatar
The OBD II spec states the downstream sensor not only monitors the health of the converter but also _protects_ the health of the converter. As such, the downstream sensor can countermand the upstream sensor in order to protect the converter.
There's numerous instances of people changing the upstream sensor because their fuel economy has dropped, only for there to be no improvement. Changing the downstream sensor remedies the issue.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #10 of 14 Old 08-14-2020, 07:37 AM
LordHobbit
LordHobbit's Avatar
I'd cut the wires right next to the connector so the connectors stay clean until it gets replaced.
Again, don't short them.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #11 of 14 Old 08-17-2020, 09:27 AM Thread Starter
demagogue
demagogue's Avatar
Thanks...ZJ is currently up on jack stands and replacing everything. PCM seems to be fine so fortunately the wires didn't short. Not looking to replace the PCM again.
Pretty pissed, they cut into the Y pipe in a few places so I have to replace that as well. It's a real pain.
1997 ZJ Limited
1974 Ford F-100
post #12 of 14 Old 08-19-2020, 02:19 PM Thread Starter
demagogue
demagogue's Avatar
Turns out the thief ripped the connector the o2 sensor connects to out. I'm having a hell of a time finding pigtail connector to fix this. Anyone have thoughts on the part number potentially?
1997 ZJ Limited
1974 Ford F-100
post #13 of 14 Old 08-19-2020, 04:04 PM
zjosh93
Someone will probably jump in after me and prove me wrong but I think those are junkyard parts now. It's not the same connector, but I could not find the harness connector for the oxygen sensor on my 93. And a little searching didn't turn up the one for your 97.
zjosh93 is offline
post #14 of 14 Old 08-22-2020, 10:38 PM
riiz
riiz's Avatar
You can splice in the 02 sensor and remove the connector from the sensor's pigtail.
riiz is online now
5.2 , cat , catalytic converter , o2 sensor
