Do I need to pull my valve cover again? - JeepForum.com
 1Likes
  • 1 Post By Timo_90xj
post #1 of 9 Old 02-22-2020, 01:22 PM Thread Starter
Bryan B.
Bryan B.'s Avatar
Need a picture of the top of 97 4.0 head
Anyone have a picture of the top of head/rocker assembly of a 97 Grand Cherokee? I put a new valve cover gasket on ( Fel Pro Permadry) with no issues... I thought.
While cleaning up I went to throw away the old gasket and realized it had two holes in it that the Fel Pro didn't have.
The holes are on the passenger side of the gasket on the flat steel strap that runs from left to right between the rocker assembly. I need to know if there is a hole in the top of the head where the holes are in the gasket, maybe an oil jacket or if it's something I dont need to worry about.
Bryan B. is offline
post #2 of 9 Old 02-22-2020, 05:51 PM
zjosh93
I believe they just help locate the gasket.
Skip to about 6:55.
zjosh93 is offline
post #3 of 9 Old 02-22-2020, 07:03 PM
StPaul59
That's the worst feeling. That moment when you start thinking, Oh what have I screwed up now??!
StPaul59 is offline
post #4 of 9 Old 02-23-2020, 02:52 AM Thread Starter
Bryan B.
Bryan B.'s Avatar
Skip to about 6:55.
Looks like I'm pulling the cover off again tomorrow. The holes I'm talking about are clearly shown on the gasket in the video before you even play it. I'm assuming I got one that never got those punches out. Oh well, live and learn. If they're needed I'm glad I haven't driven it more than down the street and back. Here goes another two hours of my life I'll never get back.
Bryan B. is offline
post #5 of 9 Old 02-23-2020, 05:42 AM
3hounds
You don't have to remove your gasket again, it only goes on 1 WAY. The holes are ALIGNMENT DOWELS.
3hounds is offline
post #6 of 9 Old 02-23-2020, 05:56 AM
Timo_90xj
Timo_90xj's Avatar
Why would you need to pull the valve cover if the gasket sits in its place like it should and you have no leaks? As was mentioned those holes are there just for alignment, and IIRC not all 4.0 cylinder heads even has those locator pins.
3hounds likes this.
***Under construction***
Timo_90xj is offline
post #7 of 9 Old 02-23-2020, 04:38 PM
zjosh93
My 93 doesn't have them. Looking at the parts listing they were 96 and up only.
zjosh93 is offline
post #8 of 9 Old 02-24-2020, 07:41 AM
paulvon
Alignment only.
If you are not leaking don't worry about it.
Sent from my SM-G920V using Tapatalk
1997 ZJ 4.0 L - Upgraded to heavy 93 sway bar
2004 WJ 4.7 L - 2 1/2" lift
2011 KK 3.7 L
paulvon is offline
post #9 of 9 Old 02-24-2020, 10:11 PM Thread Starter
Bryan B.
Bryan B.'s Avatar
Originally Posted by paulvon View Post
Alignment only.
No leaks, runs great! Thanks
Bryan B. is offline
