Disable dimmer because of dash lights flickering - JeepForum.com
post #1 of 2 Old 04-03-2020, 02:20 PM Thread Starter
delmanciomio
Hi, I bought my 1997 ZJ not a long time ago. I have very annoying problem. If dimmer switch is up (not until interior lights on) my lights wont flickering.
But this time when i shut of my car, dash lights will stay on. Even i turn headlight switch to off position. When this is happening i slide dimmer down i hear click noise and lights turn off. But if i keep slider down middle or almost up position dash lights will flicker if headlight switch not off position.
Is there any way to skip dimmer ? Which cables i need to jump?
I want full brightness no matter headlight switch is on or off.
Hope i explain my problem well
Thank you
delmanciomio is offline
post #2 of 2 Old 04-03-2020, 04:33 PM
1996maroonzjf
1996maroonzjf's Avatar
The flickering of the dash lights is a very common problem in ZJs and is caused by cracks it in solder joints of the internal circuit board of the headlight switch. The solder joints can be re-flowed fairly easily as shown in the below link. I repaired the headlight switch in my ZJ over 8 years ago it it hasn't flickered again since. There are also youtube video showing how to repair.
https://www.jeepforum.com/forum/f13/...-heavy-702703/
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is offline
