Did I push my new axle in too far? - JeepForum.com
 3Likes
  • 2 Post By GOLDWING
  • 1 Post By GOLDWING
post #1 of 5 Old 07-05-2021, 06:42 PM Thread Starter
norconick
I'm redoing the front end on my 1998 ZJ 5.9 and I've gotten new axle shafts for it. I slid the driver side axle in nice and gently and confirmed it was engaging by spinning it by hand and seeing the pinion move as well. I took it out and put it back in and now the pinion isn't spinning with it anymore. The front drive shaft is currently disconnected from the Jeep.
The reason I took it out in the first place is because I noticed it doesn't have the out axle tube "seal", so I may have pushed it in further than it would have gone with the outer axle tube seal.
Is it possible to dislodge something in the differential by pushing in the axle shaft too far? Any ideas why the pinion isn't spinning with the axle anymore?
'98 ZJ 5.9 Limited -- 284k kms
'08 Escape Hybrid AWD -- 532k kms
'04 VW Jetta TDI -- 408k kms
norconick is offline
post #2 of 5 Old 07-05-2021, 06:56 PM
GOLDWING
GOLDWING's Avatar
I am sure that it is just that the side and spider gears are rotating in the diff. carrier rather than rotating the pinion.
IMHO outer seals keep in more crap than they keep out. They should have no effect on the depth of the axle in the housing.
Timo_90xj and norconick like this.
"The Dude Abides"
"Your axles are going to turn into spaghetti noodles."
Polka Power 1/3/2021
GOLDWING is offline
post #3 of 5 Old 07-05-2021, 07:06 PM Thread Starter
norconick
Update: I vacuumed the rust out of the axle tube and tried again and it works again. I'm still curious as to what happened though.
post #4 of 5 Old 07-05-2021, 07:49 PM
jeepjeepster
Did you have the other axle shaft in? Are you sure it wasnt just spinning? Its an open diff, so the pinion doesnt HAVE to spin...
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #5 of 5 Old 07-05-2021, 11:56 PM
GOLDWING
GOLDWING's Avatar
Timo_90xj likes this.
"The Dude Abides"
GOLDWING is offline
