In the deep mud, tore my evap canister off - JeepForum.com
 1Likes
  • 1 Post By PolkaPower
post #1 of 8 Old 06-21-2021, 02:23 PM Thread Starter
i-joshua
i-joshua's Avatar
I heard a noise like "plop, plop, plop, ..." and I discovered that it had no canister evap.
I will order one but, can i bypass the 2 hoses and use my jeep while i don't have the new one? My evap canister is the round model, with only one inlet. 2 hoses arrive at that entrance.
ZJ 5.2 V8 from La Coruña, Spain
i-joshua is offline
post #2 of 8 Old 06-21-2021, 02:59 PM
HighLonesome
HighLonesome's Avatar
connect the two hoses together
HighLonesome is offline
post #3 of 8 Old 06-21-2021, 04:28 PM
PolkaPower
PolkaPower's Avatar
I connected the hoses together with a T vent.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #4 of 8 Old 06-21-2021, 05:20 PM
HighLonesome
Why a T Polka? Where did the 3rd port go?
I was thinking using a straight barrel connector would keep dirt out of the tank and TB. And maybe still vent the tank into the TB.
post #5 of 8 Old 06-21-2021, 05:27 PM
PolkaPower
PolkaPower's Avatar
It vents pressure that builds up in the tank.
post #6 of 8 Old 06-21-2021, 11:46 PM Thread Starter
i-joshua
i-joshua's Avatar
The T open to the atmosphere? Could dirt get into the admission?
i-joshua is offline
post #7 of 8 Old 06-22-2021, 12:41 AM
PolkaPower
PolkaPower's Avatar
You can put a one way valve or filter on it. Or just connect the lines and try to find a vented gas cap.
I hooked the lines up with no vent and I noticed quite a bit of pressure build up in the gas tank from time to time. I'll probably just look fo a smaller canister that fits in the engine bay.
HighLonesome likes this.
post #8 of 8 Old 06-22-2021, 07:30 AM
Timo_90xj
Timo_90xj's Avatar
It's actually vacuum that forms into the tank, not pressure
That being said, do what has been suggested above.
***Under construction***
Timo_90xj is offline
