Decent Brake Caliper source?? - JeepForum.com
 3Likes
  • 1 Post By StPaul59
  • 1 Post By underscore
post #1 of 11 Old 12-09-2019, 08:05 PM Thread Starter
StPaul59
I replaced my calipers in 2017 with ones from Napa. Drivers side just recently seized and replaced with another Napa one. Now I get a pull to the left because the 'old' pass side caliper is lazy. Jesus.
If you can't trust Napa for brakes, who can you go to for a freaking oem
style caliper?
StPaul59 is offline
post #2 of 11 Old 12-09-2019, 10:56 PM
GOLDWING
GOLDWING's Avatar
style caliper?
I, and Jeep Girl watch over 16 calipers so I am also curious?????
GW
"The Dude Abides"
GOLDWING is offline
post #3 of 11 Old 12-09-2019, 11:51 PM
Kolak
Vendor
Kolak's Avatar
Crown Automotive has excellent brand new (not remanufactured) calipers.
Do you need fronts or rears?
Are the rotors and pads still OK?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #4 of 11 Old 12-10-2019, 12:23 AM
Timo_90xj
Timo_90xj's Avatar
The problem is the idiotic composite pistons, stupidest idea ever. Should be stainless steel so they wouldn't swell and/ or seize.
But as Kolak mentioned, brand new calipers is the way to go. Remanufactured parts tend to be more or less crappy.
***Under construction***
Timo_90xj is offline
post #5 of 11 Old 12-10-2019, 08:29 AM Thread Starter
StPaul59
Agreed.
StPaul59 is offline
post #6 of 11 Old 12-10-2019, 08:30 AM Thread Starter
StPaul59
Pads are great, brand new coated rotors. Fronts.. Hawk pads and Raybestos rotors.
Kolak likes this.
StPaul59 is offline
post #7 of 11 Old 12-10-2019, 09:11 AM
LordHobbit
LordHobbit's Avatar
I've rarely got good parts from NAPA. I avoid them as much as possible.
I've purchased new steel piston calipers for two different vehicles from o'rielly auto and have not had any problems with them.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #8 of 11 Old 12-10-2019, 12:47 PM
Kolak
Vendor
Kolak's Avatar
Great. If you'd like pricing for calipers, you can PM me here on the forum or email me at [email protected]
or
Kolak is online now
post #9 of 11 Old 12-10-2019, 02:06 PM
zjosh93
RockAuto has rebuilt calipers with steel pistons. Cardone 184340S (Left) and 184339S (Right). Run about $24 with a $25 core. I went through the same rigmarole on my 93. Kept pulling this way or that. Put on a pair of the steel piston versions and it was a ton better. It would still track slightly if I hit the brakes hard. I replaced the shocks and that little bit went away. I rationalized it as uneven body dive under hard braking.
They used to sell steel pistons individually so you could just swap them. Around $10 IMS. Not available on RockAuto now but maybe out there.
zjosh93 is online now
post #10 of 11 Old 12-10-2019, 02:27 PM
underscore
2007 WK
Parts stores give you junk by default, order from Kolak or RockAuto and select something that's actually quality.
Kolak likes this.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #11 of 11 Old 12-11-2019, 09:00 AM Thread Starter
StPaul59
GW
Kolak always has the answer.
Kolak likes this.
StPaul59 is offline
