Death wobble - JeepForum.com
post #1 of 10 Old 05-02-2019, 10:36 AM Thread Starter
TVILLEDAWG2370
Death wobble
I own a 1997 ZJ...and it has the dredged death wobble...should I start with getting a new trac bar?
TVILLEDAWG2370 is offline
post #2 of 10 Old 05-02-2019, 11:10 AM
BlueMagnus
BlueMagnus's Avatar
Get down there and check what's worn first. I had to replace anything with a bushing. The shake went from "Gonna die here" to a slight shake. Tires and alignment are next.
Go under your jeep and start grabbing and moving things, listen for clunks and look for things leaking grease.
BlueMagnus is offline
post #3 of 10 Old 05-02-2019, 11:55 AM
firebane
Death wobble is very seldomly one thing and more of many things failing.
Being that you've experienced death wobble that just puts more stress on the worn parts you have already.
firebane is offline
post #4 of 10 Old 05-02-2019, 01:01 PM
Timo_90xj
Timo_90xj's Avatar
My ZJ went from zero DW (no steering stabilizer) for the past 7 yesrs to slight shake on certain bumps to experiencing DW once within a couple weeks. After getting DW once, it went so bad I was affraid to hit speeds over 40mph.
The only thing causing my DW is worn TREs.
But it can be many things causing it, and most often it's a combination of some of the following: worn TREs, worn trackbar bushing(s), worn steering box, worn balljoints, cracked uniframe in trackbar bracket/ steering box area, ovalized front TB mounting bracket hole in the axle, incorrect steering angles/ incorrect steering geometry on lifted vehicles.
Contributing factors are wrong tire pressures, uneven tire wear, bad shocks to name a few.
***Under construction***
Timo_90xj is offline
post #5 of 10 Old 05-02-2019, 01:35 PM Thread Starter
TVILLEDAWG2370
It had a 3.5 inch lift from rough county about 2 years ago,...also the drag link seems to have some play in it,I know there's supposed to be some,but how much is to much? I have great tire wear,even all the way
post #6 of 10 Old 05-02-2019, 01:48 PM
Timo_90xj
Timo_90xj's Avatar
Draglink, tierod, TREs and trackbar should have zero play. Draglink and tierod do suffer from "tierod- roll", but any amount of play is too much.
What is your caster angle, and how much toe-in?
post #7 of 10 Old 05-02-2019, 03:25 PM Thread Starter
TVILLEDAWG2370
On the draglink I can move it up and down but not left to right,could that be part of the problem also....I'm not really sure about the other question you asked,
post #8 of 10 Old 05-02-2019, 03:26 PM Thread Starter
TVILLEDAWG2370
I'm not really sure about caster angle or toe in
post #9 of 10 Old 05-02-2019, 03:56 PM
firebane
If you got a lift you should know this information. If you do not then either you haven't gotten an alignment or didn't do a backyard alignment to get it close.
I'd suggest taking it in for a check on the front end then work from there.
firebane is offline
post #10 of 10 Old 05-02-2019, 08:19 PM
V8GCZJ
YES!
V8GCZJ is offline
Death Wobble + Knocking Noises... a Jeep nightmare. HeyAwesomePeopl XJ Cherokee Technical Forum 19 02-12-2019 10:59 PM
2003 Jeep WJ Track Bar/ Death Wobble Issue Jmonroe98 WJ Grand Cherokee Forum 3 04-27-2018 04:35 PM
Death Wobble with a twist dwarren05 WJ Grand Cherokee Forum 10 04-08-2018 09:41 AM
Death Wobble and Steering Issues pmarascal JK Wrangler Technical Forum 6 02-26-2018 01:28 AM
