Cylinder head question - JeepForum.com
post #1 of 10 Old 02-24-2018, 02:19 PM Thread Starter
devildawgg42
So,
I have my heads out and in one of them there is a Hairline crack (it seems).. So, my question is; Do I get an all new head? Or do I attempt to put it back? Also, If I decide to get a new head, should I replace in pairs? Or will I be fine milling the good one and replacing the old one?
devildawgg42 is offline
post #2 of 10 Old 02-24-2018, 02:31 PM
paulsheer2
Originally Posted by devildawgg42 View Post
So,
I highly recommend hughes engines performance iron heads with larger stainless valves.
I have a pair.
I use stock springs.
BTW do NOT get the crack welded -- mine cracked again :-(
Paul
93 ZJ 5.2, 3.58 stroked. 242 swap. 2.5" lift. dozens of mods.
paulsheer2 is offline
post #3 of 10 Old 02-24-2018, 02:31 PM
jtec
jtec's Avatar
2014 JK Wrangler
nice to know which engine...5.2? maybe
Is there a crack or not machine shop can tell AND advise if the remaining head is worth reusing and if necessary matched to replacement.
jtec is offline
post #4 of 10 Old 02-24-2018, 02:44 PM
PolkaPower
PolkaPower's Avatar
Ratmonkey used to say that he never saw V8 magnum heads that weren't cracked. RIP.
Sent from my BND-L24 using Tapatalk
PolkaPower is offline
post #5 of 10 Old 02-24-2018, 02:47 PM
Timo_90xj
Timo_90xj's Avatar
I'm suspecting a V8 since OP is talking about cylinder heads, not one cylinder head.
A lot of 5.2/ 5.9 heads have hairline cracks, and most people ditch them at that point and get something that flow better. The stock heads restrict airflow a lot, so a set of EQ/ Indy cast iron large valve heads is a good option. Or if there are no plans for any upgrades, just get stock replacements for dirt-cheap.
That being said, if they really are hairline cracks and you haven't had any coolant loss issues, you could just clean 'em, check 'em, and simply run them as is. There are probably about a couple million 5.2/ 5.9 engines on the streets running fine that have stock hairline-cracked heads
***Under construction***
Timo_90xj is offline
post #6 of 10 Old 02-24-2018, 03:18 PM Thread Starter
devildawgg42
It's a 5.2L And I have been looking at aftermarket heads.. I am just not sure I want to pay the money right now, I also don't want to break them out again haha... Anyhow, Thank you for the input! And it looks like there is a crack between the Valves.. That's the issue..
post #7 of 10 Old 02-24-2018, 03:44 PM
GOLDWING
GOLDWING's Avatar
RA has new bare heads for $213 each.
ENGINETECH EHCR3181 Bare Head Info
New bare head without valves or springs. 62cc Casting # 466,671.3126" guide ID. Valve head diameter 1.920 / 1.624".
Previous Image
Next Image
$213.79 $0.00 $213.79
GW
"The Dude Abides"
GOLDWING is offline
post #8 of 10 Old 02-24-2018, 04:03 PM Thread Starter
devildawgg42
Looking at the JEGS bare head... Good price, what yall think?
post #9 of 10 Old 02-24-2018, 04:40 PM
kg6mov
Hears the voices
kg6mov's Avatar
A new head is gonna be better than a cracked head. Not by much if the rest of the engine is the same, kinda comes down to what the piece of mind is worth to you.
kg6mov is offline
post #10 of 10 Old 02-27-2018, 11:45 PM
CatSplat
CatSplat's Avatar
1994 ZJ
The Magnum head cracks between the valve seats are pretty much a non-issue unless they get so bad they start seeping coolant. Probably 99% of 5.2/5.9s on the road have cracked heads. You can always reinstall them and save for better ones to install later.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 33" Cooper Discoverer STT Pro
The Jeep of Theseus
CatSplat is offline
