CV axle help - JeepForum.com
 1Likes
  • 1 Post By MackJartel
post #1 of 6 Old 07-25-2021, 11:53 PM Thread Starter
MackJartel
CV axle help
I’m looking to replace my CV axles on my 1995 Grand ZJ 5.2 as the boots are both ripped and they’re 26 years old But when I called the parts store they asked me which one I needed. There are 2 different ones and I’m not sure how to find out?
I’m also having a 3 inch lift installed. Will that change anything?
HighLonesome likes this.
MackJartel is offline
post #2 of 6 Old 07-26-2021, 12:28 AM
riiz
riiz's Avatar
What is the difference between the 2 axles, maybe the parts store meant which side, because of the different lengths. I looked on Rockauto.com and you can get both axle shafts shipped for about $110.
But you will probably want or need to swap out that front drive-shaft and yoke on the axle. The rzeppa-joint on the front of it, will not live long off-road with a 3" lift.
riiz is offline
post #3 of 6 Old 07-26-2021, 01:26 AM
Timo_90xj
Timo_90xj's Avatar
Front - and rear for that matter - left & right axle shafts are different length. You can use u-joint- style or CVs, whichever you prefer, both styles need to have ABS tone rings in the stub shafts if you want to keep your ABS functional.
***Under construction***
Timo_90xj is offline
post #4 of 6 Old 07-26-2021, 01:28 AM
PolkaPower
PolkaPower's Avatar
CV axle help
Tell them you need both.
Also 93-95 mostly came with u joint front shafts. My early build 95v8 had a u joint but I test drove a late build 95 v8 with the rzeppa shaft so he might have a u joint shaft already if he's lucky.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #5 of 6 Old 07-26-2021, 04:41 PM
GOLDWING
GOLDWING's Avatar
Originally Posted by MackJartel View Post
Iím looking to replace my CV axles on my 1995 Grand ZJ 5.2 as the boots are both ripped and theyíre 26 years old But when I called the parts store they asked me which one I needed. There are 2 different ones and Iím not sure how to find out?
Iím also having a 3 inch lift installed. Will that change anything?
I recommend doing both axles as Polka mentioned, but I would also replace the bearing/hub assemblies at the same time. Doing them separate is a time suck and doing them together is not.
Also, if you buy from Rock Auto, you can get hub/bearings and axles for the price of axles alone at Auto Zone/ Advance etc. etc.
"The Dude Abides"
"Your axles are going to turn into spaghetti noodles."
Polka Power 1/3/2021
GOLDWING is offline
post #6 of 6 Old 07-26-2021, 08:08 PM
jeepjeepster
Ive taken a liken to just replacing the boots. Napa carries them.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
