Crank No fuel no spark - JeepForum.com
 1Likes
  • 1 Post By jeffries_900
post #1 of 8 Old 07-26-2021, 09:50 AM Thread Starter
jeffries_900
Hello Just bought a 1993 Grand Cherokee limited 5.2 I was told it had a bad fuel pump so i replaced the fuel pump.
It started and ran for 8 Min then died and would not restart no fuel pressure or spark has voltage at coil but no pulse when starting. I tested the cam sensor and it was good i replaced the crank sensor and still does same.
If I turn the key on and leave for 5 min the asd relay will click for a few and stop then i have fuel and spark and it will run for a while and then die. I also have cleaned the computer connections and battery cables at the battery.
The security wire by the kick panel has been grounded, but have noticed if i leave the key on for 5 min the security light on the dash comes on.
jeffries_900 is offline
post #2 of 8 Old 07-26-2021, 04:47 PM
RedRiverT
Maybe the ASD relay has a problem. I don't know about a '93, but it is probably the same model of relay as the A/C or horn, so you can switch them and see if it will run. Also check the prongs on the relay and the sockets they plug into.
RedRiverT is offline
post #3 of 8 Old 07-26-2021, 05:16 PM
PolkaPower
PolkaPower's Avatar
Does it crank? No crank could be the neutral safety switch too. Usually reverse lights are gone as well when it's bad or unplugged.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #4 of 8 Old 07-27-2021, 04:41 AM
V8GCZJ
V8GCZJ is offline
post #5 of 8 Old 07-27-2021, 06:50 AM Thread Starter
jeffries_900
It will crank every time just will not start. you can turn the key on for 5minutes and the asd relay will click and make noise then it will stop. I then check and i have fuel pressure and spark and it will start but later will die.
I have switched relays and cleaned with key on (on the Asd relay) all terminals but one are 12v and one ground.
But now i have noticed if i leave the key on for over 5 3 min the security light on the dash comes on
Also i have no been able to produce any codes
Thanks Clay
post #6 of 8 Old 07-28-2021, 06:44 AM Thread Starter
jeffries_900
I did notice the engine light flashing everytime the asd relay clicked. but once it runs for few min it dies and will not started or asd will not click
post #7 of 8 Old 07-29-2021, 04:54 AM
V8GCZJ
Asd relay will only come on when you turn the ignition to on/crank. If you leave the key in the on position(not cranking) the asd relay will shut off after a few seconds. Even if you have no codes you should get a 55 code meaning end of codes.
V8GCZJ is offline
post #8 of 8 Old 07-30-2021, 11:57 AM Thread Starter
jeffries_900
***FIXED****
After doing more testing I replaced the three Capacitors on the computer board.
hilljacknm likes this.
