coolant temp sensor problem can't find the right part - JeepForum.com
post #1 of 17 Old 01-14-2015, 01:14 AM Thread Starter
tylersjeep
1994 ZJ
So I went to replace the coolant sensor today and found out I have a one pin connector but the part store says I have a 2 pin connector everywhere I look its say 2 pins but it only fits 1 pin I found this odd I got a junk yard intake with this same 1 pin connector WTF going on? dose anyone have the real part number?
tylersjeep is offline
post #2 of 17 Old 01-14-2015, 01:54 AM
AVR2
You have two coolant sensors. I don't have the exact locations for the 5.2L, but one of them is a 2-pin and feeds the PCM, and the other is a 1-pin that drives the dash temp gauge. Later ZJs did away with the 1-pin and drove the gauge off the PCM sensor.
The part number you want is 56027012. You can take a look at one at RockAuto here. Click the "Next Image" arrow on the picture to cycle through and confirm that it's the 1-pin type you need. I've actually had that specific Standard Motor Products one in my 4.0L for the last 4 years.
AVR2 is offline
post #3 of 17 Old 01-14-2015, 02:09 PM Thread Starter
tylersjeep
1994 ZJ
I don't buy Standard Motor Products junk I only buy mopar. it ended up being being called coolant temp switch not sensor
post #4 of 17 Old 01-14-2015, 03:04 PM
PolkaPower
PolkaPower's Avatar
Regardless, OBDI(93-95) has 2 and OBDII(96-98) has one. You were told. Be more gracious next time someone helps you, if they bother.
PolkaPower is online now
post #5 of 17 Old 01-14-2015, 03:52 PM
Cbob4
Cbob4's Avatar
Originally Posted by polkapower View Post
regardless, obdi(93-95) has 2 and obdii(96-98) has one. You were told. be more gracious next time someone helps you, if they bother.
x2...
Cbob4 is offline
post #6 of 17 Old 01-14-2015, 04:17 PM
MrRoundel
Originally Posted by Cbob4 View Post
x2...
x3
While Standard stuff may not be as good as it used to be, I still find it better than a lot of other brands out there these days. It's the way of the world. It's hard to find quality parts, quality partners, and quality traits. At least I can still find a good beer out there.
MrRoundel is offline
post #7 of 17 Old 01-14-2015, 05:55 PM
6x-gpapa
X4
don't ask for help and screen out loud. be circumspect.
6x-gpapa is offline
post #8 of 17 Old 01-14-2015, 05:57 PM
Technohead
Technohead's Avatar
Whatever it is, once you replace it you will learn that the coolant temp sensor was not the problem but the silly VIC was . . .
Google is your friend.
-Eric
Technohead is offline
post #9 of 17 Old 01-14-2015, 08:56 PM
1998_ZJltd
but dont ask how to fix it here .... unless the attitude is a little bit better .....
1998_ZJltd is offline
post #10 of 17 Old 01-14-2015, 09:45 PM
AVR2
Well, as I mentioned my Standard temp sensor is working just fine after 4 years and it cost me about $10. Since all it does is drive the dash gauge I didn't see the point in spending almost three times that on a Mopar original.
That's a thought. I assumed that he wanted the coolant temp sensor because his gauge wasn't working. I didn't think that it might be because he was getting "coolant sensor bad" messages on the VIC.
AVR2 is offline
post #11 of 17 Old 01-14-2015, 11:54 PM
dflewelling
Is what you're looking for called a "coolant temperature sending unit" rather than coolant temperature sensor?...or are the terms used interchangeably...lpl
dflewelling is offline
post #12 of 17 Old 01-15-2015, 12:29 AM
AVR2
I've given him the correct part number. What he does with that information is up to him. Although given the way he responded, I've got a couple of suggestions
But it's actually called "SWITCH, Eng. Temp." in the Mopar parts catalog.
AVR2 is offline
post #13 of 17 Old 01-19-2015, 03:08 PM Thread Starter
tylersjeep
1994 ZJ
it's actually called coolant temperature switch not coolant temperature sensor there are two very different things try walking to autozone and ask for a coolant temperature sensor they're going to look at you 4 heads especially when you mention the dash gauge which is coolant temperature switch not sensor trust me I tried this for a good two weeks going to different parts stores asking for a coolant temperature sensor not switch and I do know what I need because my temperature switch is broken in half. and for standard motor produc I bought an ECU from from it broke 3 miles down the road and then map sensor that I have stop working after 3000 miles departureit broke 3 miles down the road and then map sensor that I had stopped working after 3000 miles the part is junk
post #14 of 17 Old 01-19-2015, 03:09 PM Thread Starter
tylersjeep
1994 ZJ
and the temperature switches 1 pin temperature sensor is 2 pins
post #15 of 17 Old 01-19-2015, 03:32 PM
kg6mov
Hears the voices
kg6mov's Avatar
The vic doesn't monitor the temp, it monitors the level in the overflow bottle.
kg6mov is offline
