Coolant Recommendation? - JeepForum.com
 8Likes
post #1 of 16 Old 08-04-2020, 11:29 PM Thread Starter
Rigged For Adventure
I'm usually a great internet searcher, but I came up short this time (must be getting old ha!)
I'm looking for a coolant recommendation for my 97 ZJ 5.2L. Please lmk!
Rigged For Adventure is offline
post #2 of 16 Old 08-05-2020, 12:49 AM
Zilliver
The green one is used from factory.
98 Grand Cherokee 5.9 - daily
95 Grand Cherokee 5.2 - offroad
Zilliver is offline
post #3 of 16 Old 08-05-2020, 02:47 AM
LittleFootZJ
My 96 5.2 I use 50/50 green.
Sent from my iPhone using Tapatalk
LittleFootZJ is offline
post #4 of 16 Old 08-05-2020, 03:46 AM
GC2013
Valvoline Zerex g-05 is my choice. Green one. I use for both 4.7 and 5.9.
Sent from my iPhone using Tapatalk Pro
GC2013 is offline
post #5 of 16 Old 08-05-2020, 01:31 PM
Timo_90xj
Timo_90xj's Avatar
Normal good 'ol green , 50/50 mix.
***Under construction***
Timo_90xj is offline
post #6 of 16 Old 08-05-2020, 06:29 PM
jeepjeepster
Say wha? G05 is the correct fill for the 4.7 but it is not for the 5.9. It can be used if you flush the system very well. Its in a gold bottle and its a yellow color, not green.
Zerex in the white bottle is what I buy. For some strange reason, a local IGA (food store) is the cheapest place around. I loaded up last time I went.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #7 of 16 Old 08-05-2020, 07:44 PM Thread Starter
I'm seeing the Prestone 50/50 Prediluted Antifreeze and Coolant. Is that what you guys mean by "50/50 green"?
LittleFootZJ and Ksim46 like this.
post #8 of 16 Old 08-06-2020, 11:36 AM
jeepjeepster
Ive always steered clear of the 'all makes all models' stuff b/c idk what it is. You can buy the 50/50 already mixed or you can buy the concentrate and mix it 50/50 with water. Personally I always buy the concentrate and use distilled water. I dont like paying a premium for water.
post #9 of 16 Old 08-07-2020, 09:49 AM Thread Starter
What brand of concentrate do you recommend for our ZJs? I would rather mix it myself as well.
post #10 of 16 Old 08-07-2020, 10:42 AM
kg6mov
Hears the voices
kg6mov's Avatar
Prestone is pretty good, I use that or peak to fill our ZJ's.
kg6mov is online now
post #11 of 16 Old 08-07-2020, 04:44 PM
jeepjeepster
post #12 of 16 Old 08-07-2020, 11:21 PM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
Zerex Traditional/Green is what I would also advise, also referred as IAT. It can get hard to come by; I get it through Amazon. It contains silicate and your entire cooling system is coated with it to prevent corrosion. If you use the wrong formula, any trace amount of the old coolant will react with the new one and may be a recipe for disaster. The green coolant requires a 2 years service interval but it's cheap insurance IMO.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, 703s injectors, Jones Exhaust A3518M-5
rep-tile is offline
post #13 of 16 Old 08-08-2020, 12:20 AM Thread Starter
Looks like Zerex it is. Just did a quick Amazon search and I'm not seeing that exact bottle that @jeepjeepster posted, but I believe this one is the same right? (just newer design)
Zerex Original Green 50/50 Prediluted Ready-to-Use Antifreeze/Coolant 1 GA
post #14 of 16 Old 08-08-2020, 12:41 AM
phatbuddha
On Amazon, it would be this one. The concentrate.
Zerex Original Green Antifreeze/Coolant 1 GA
https://www.amazon.com/dp/B000CNJ6JG...NsaWNrPXRydWU=
phatbuddha is offline
post #15 of 16 Old 08-08-2020, 07:59 AM
jeepjeepster
Guess Im behind the times. As far back as my memory goes, zerex original has been in a white bottle. Guess they somewhat recently switched to grey.....
Anyway, that stuff is $13 at my local IGA.
