Common ZJ Problems / Tutorial On How To Fix Them - Page 19 - JeepForum.com
 1Likes
post #271 of 283 Old 07-30-2015, 11:52 AM
cutherland95
Has anyone had issues with 4x4? I engage it and it doesn't work, and grinds. I'm thinking TC, but wanted to see if anyone else had a different opinion before I pull it off.
cutherland95 is offline
post #272 of 283 Old 07-30-2015, 11:54 AM
kg6mov
Hears the voices
kg6mov's Avatar
Shifting from 4ft to 4lo on your niner?
How are you shifting? In neutral barely rolling?
kg6mov is offline
post #273 of 283 Old 08-02-2015, 07:46 PM
RodrigoVolpato
hi, try to ajust the handle position, 4wd to neutral and 4low, maybe it is in a wrong position! my jeep did the same thing, I just ajust the handle! it is located in the front of the TC, very easy to
ajust! regards
RodrigoVolpato is offline
post #274 of 283 Old 08-02-2015, 08:01 PM
RodrigoVolpato
Hi Guys, my 98 zj v8 engine have some problems with the transmision! let me explain. when I'm driving in the city, all the four gear are working well. When I got muddling in low range my jeep just stay in the 1st gear and don't any gear more. Turn to hi 4wd the problem is solved, all the four gear works well. I changed the speed sensor, but still the same thing! Does anyone knows what it could be???
post #275 of 283 Old 10-17-2015, 01:56 PM
mybabyjasper
#8. rear wiper not working: i've had it happen multiple times - take off the arm and tighten the teeth alignment. it usually just slips off tracks and then won't grip.
mybabyjasper is offline
post #276 of 283 Old 10-17-2015, 01:58 PM
mybabyjasper
PCM/ECM flaw
you also left out the slew of issues that arise from the bad PCM/ECM. SO MANY ISSUES COME FROM THIS and it's a SUPER common flaw in ZJs.
post #277 of 283 Old 10-17-2015, 09:20 PM
ZeeJay1997
That would be a great write up if someone were so inclined.
ZeeJay1997 is offline
post #278 of 283 Old 10-29-2015, 03:24 PM
Fenian
I have a wierd one....my high beams work, and they go from high to low and back no problem, but my blue indicator light in the instrument cluster won't come on. I have removed the clluter adn checked the bulb and it is fine.
Fenian is offline
post #279 of 283 Old 11-21-2015, 04:39 PM
Detroitwrecker
2006 KJ Liberty
Both front seats stopped working
2006 Jeep liberty 3.7 Limited. Loaded. Leather power heated seats. The heated seats work great but, all of the sudden both front seats will not adjust at all. I went loking for the fuse ALL fuses in under hood and JB inside jeep on drivers side is good. I keep being told there is a circuit breaker, I even bought the circuit breaker. My problem is that, NO ONE seems to know where this circuit breaker goes. I am aware of the relays and circuit breakers on the opposite side of the interior fuse panel but I have yet to find a diagram explaining what each one is???? WILL SOMEONE PLEASE HELP ME!!??? Most of my hair is gone and I'm in my forties hoping to keep my hair! Does anyone have a detailed diagram and explanation of ALL FUSE PANELS AND JB'S??? Or you can just tell me where tey are so I can get my power seats working again. PLEASE.
Detroitwrecker is offline
post #280 of 283 Old 11-21-2015, 05:26 PM
kg6mov
Hears the voices
kg6mov's Avatar
This is the ZJ (1993-1998 Grand Cherokee) section of the forum. The vehicles are not similar. You will have much better luck posting in the KJ section of the forum over here: https://www.jeepforum.com/forum/f28/
kg6mov is offline
post #281 of 283 Old 11-25-2015, 07:44 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey Detroit wrecker,
You can access this info on pg. 350 of your owner’s manual. You can access your owner’s manual by using this link: http://www.jeep.com/en/owners/manuals/. Please let me know if you have any questions.
JeepCares is online now
post #282 of 283 Old 01-11-2016, 02:59 PM
Para32
A GREAT Summary, but half of these links are dead now....
Para32 is offline
post #283 of 283 Old 01-11-2016, 08:43 PM
Uniblurb
Uniblurb's Avatar
The original thread within this thread with live links can be linked through this post.
https://www.jeepforum.com/forum/f13/c...l#post27084369
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
