Common ZJ Problems / Tutorial On How To Fix Them - Page 18 - JeepForum.com
 1Likes
post #256 of 283 Old 02-12-2015, 11:02 AM
BaileysZJ
1994 ZJ
That's all I found for exhaust diagnosis. It kind of works in reverse so you have to know what you need to fix. With the rough idle there is so many things it could be but I'll keep looking. I'm going through electrical now
BaileysZJ is offline
post #257 of 283 Old 02-12-2015, 11:08 AM
BaileysZJ
1994 ZJ
And that's what I found for rough idle. If you want me to look at somthing else (refers you to other parts in the book) just let me know
post #258 of 283 Old 02-13-2015, 08:54 AM
niero
Awesome. Thank you Bailey. I really appreciate it. That will help a lot.
1997 Jeep GC Laredo Tsi / 4.0 I6 / 182K miles on engine, 221,320K on Jeep / d. oil 10w30 + MMO
niero is offline
post #259 of 283 Old 02-13-2015, 08:58 AM
BaileysZJ
1994 ZJ
Anytime!
post #260 of 283 Old 03-11-2015, 08:06 AM
LonesomeDove
Originally Posted by ZeeJay1997 View Post
Take your pick
Thank you!
1, 2, 3, 4, 5 - are checked, all fine
6 - pressure a bit low: measured at accumulator port, gear selector at "1", from 52 to 88psi @1000rpm (while pulling throttle link)
8, 9, 10 - also checked and double checked, fine
11 - How can I make sure the torque converter is ok? Stall test shows 2400rpm
Stil having trouble from "N" to "D", but from "N" to "R" is ok..
LonesomeDove is offline
post #261 of 283 Old 03-12-2015, 08:11 PM
evals
Hello everyone. I haven't been on in a few years due to a "very" messy divorce and hence my 1996 ZJ has suffered some neglect. I have a few issues that need attention soon but aren't despite yet.
1..Control arm bushings are rusting but rubber is in good condition. Was going to replace all upper and lower along with the sway arm bushings. So needless to say I decided why not lift it some. Now I'm not a big fan of off road driving so I don't need anything extreme. Any suggestions on around a 3" lift that has all new springs at a fair price. Also do any of them make a stiffer spring. I really dislike the top heavy feeling my jeep has compared to my 4x4 Chevy. I'm not one for half assing anything. That usually costs me a lot more cash than I'd like. Lol
2..I have a low whining while turning at higher speeds like off ramps when the Jeep leans a little. I'm suspecting the bearing hubs are going bad. Passenger side has very slight movement when I have the wheel off the ground. If this is the problem what are a good brand to buy?
3..I need new head lights for it due to clouding. I'm getting sick of polishing them up all the time and since I work nights it's a must to see well. I was wanting to get smoked lights all around since I have a pure black ZJ and no chrome. What are some good brands and dealers?
Last I have something I think you should add to the list here because it happened to me and caused a **** ton off issues.
"PASSENGER SIDE FLOOR BOARD FLOODING"
I thought I had a leaking windshield however it turned out that the water drain was clogged and allowed water to overflow the heater core intake. It soaked the fuse panel and shorted out quite a few relays. Plus made my cab smell of mold. It took several days to dry all the flooring out "once" I removed it from the vehicle. It's quite heavy when soaked to. Lol. So needless to say it was a stupid and easily avoided issues that was a massive pain. Check those water ways below the windshield for leafs or other buildup.
evals is offline
post #262 of 283 Old 04-02-2015, 10:01 AM
variable
variable's Avatar
Fourth, swap out the Governor Pressure Sensor and Shift Solenoid. These sensors commonly go bad and can cause problems that will make you think you need a transmission rebuild. They are easily accessible by dropping the pan. I replaced my Solenoid with the upgraded Borg Warner unit.
Fifth, completely replace the TV/Kickdown cable. I have read on the forum that people have done this with success. It is a few feet long and can stretch out over time. Also check where it connects to the transmission as the connects can come loose/become disconnected.
Do you have links or part numbers for these? I get a lot of random results for these from OReily's etc.
93 ZJ V8 5.2 - K&N FIPK, lots of headaches
variable is offline
post #263 of 283 Old 04-03-2015, 06:43 AM
LonesomeDove
Hi everybody,
46re
1. having harsh switching from "N" to "D"
2. kick-down while running on 4-range firstly switches to "3" and then immediately to "2"
I did full pressure test as descrybed here
http://www.cumminsforum.com/forum/91...tml#post258206
everything is ok, except one
look,
REAR SERVO has
on "1" range 60-92psi
on "R" 160-270psi
ACCU PORT and FRONT SERVO have quite the same values
GOVERNOR PORT
on "D" range it grows from 0 to 20psi, we did it on the hoist, speed was from 0 to ~30mph
and now
pressure at overdrive port is constant, it is 55psi at any speed (I did at the moment about 90 miles and pressure still the same)
As I understand at this point it also should grows according to speed
Any ideas?
Thank you
post #264 of 283 Old 04-03-2015, 09:30 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Not a trans expert but did find this.
Originally Posted by HighLonesome
coralman is offline
post #265 of 283 Old 05-07-2015, 08:34 PM
RodrigoVolpato
Hi guys, my 98 zj 4.0L broke the valve spring last year, so I took off all the engine head and fix this problem and clean all the head 0,05mm. now my problem is a stalling in low range, around 2000 and 2,500 rpm. Could be the valves or the head????
RodrigoVolpato is offline
post #266 of 283 Old 05-14-2015, 04:57 AM
AlpineStar94
#17) whining/groaning on accelerate/decelerate
This happened to me. I bought the jeep (95 ZJ) and it whined above 10mph like you're manually rolling a remote control car. Well it lasted maybe a month and my transfer case self destructed on the interstate. Did the 242 swap and the noise is gone. Might add this as something to check, because 2 quarts of atf and or a new chain would have saved me a lot of time and money.
AlpineStar94 is offline
post #267 of 283 Old 05-14-2015, 11:23 AM
robrtsmtn
Really helpful post other than the fact all those things I just ignored I realize I can fix.
1993 ZJ 5.2 V8, 3.5 IRO lift, black steel rims 31/10.50 MTs. Aussie locker.
robrtsmtn is offline
post #268 of 283 Old 05-15-2015, 11:14 PM
TheDrummer212
Anyone have the link for the rear wiper not working? The link in the thread just leads me to a page saying "page not found".
'97 ZJ 4.0 152k
Rehab/Build thread:
jeepforum.com/forum/f13/97-zj-daily-driver-build-3140177
TheDrummer212 is offline
post #269 of 283 Old 05-19-2015, 10:32 AM
V65Ozzie
It's the window latch switch......it's always the window latch switch....LOL
V65Ozzie is offline
post #270 of 283 Old 06-20-2015, 11:35 PM
Uniblurb
Uniblurb's Avatar
And a couple months later... Here's the seized rear wiper motor write-up for the link on the 1st page which doesn't work.
https://www.jeepforum.com/forum/f13/s...-motor-398760/
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
