Common ZJ Problems / Tutorial On How To Fix Them - Page 15 - JeepForum.com
 1Likes
post #211 of 283 Old 11-24-2014, 12:50 PM
kg6mov
Hears the voices
kg6mov's Avatar
You have air in your system from when you changed the pump and t-stat. Burp the system with the jeep pointing uphill and the heat on high.
kg6mov is offline
post #212 of 283 Old 11-24-2014, 01:03 PM
spawn00001212
my 97 jeep cherokee laredo is under heating any ideas why?
spawn00001212 is offline
post #213 of 283 Old 11-24-2014, 04:11 PM
Bear304inc
I'm with kg on this one, air in the system is likely the culprit, burp that bad boy. Sounds weird but my zj needed it after t stat ad's water pump were replaced. What t stat did you put in, if it's opening prematurely it could cause under heating. And of course your rad fluid its full right?
Bear304inc is offline
post #214 of 283 Old 11-25-2014, 02:20 PM
1998_ZJltd
some one should delete this guys posts on this thread .....
I don't think he is understanding what this thread is or is about .....
1998_ZJltd is offline
post #215 of 283 Old 11-25-2014, 03:30 PM
Matta94GCL
2005 KJ Liberty
do anyone know why my jeep is under heating? I also changed the water pump and thermostat.Thats when it started.and my heat is low.first time owning a jeep cherokee laredo 1997 4x4 HELP!!!!its cold
Are you sure you're running too cold? Maybe the gauge or sensor is malfunctioning. Are you throwing a code?
Matta94GCL is offline
post #216 of 283 Old 12-01-2014, 04:50 AM
RodrigoVolpato
hello, my 98 jeep grand cherokee automatic transmission don't engage the 1st gear, just slip and go very slow. if i put manualy in 2st gear it go ok, but not in the 1st, just 2,3 an 4 gear. I check the tv cable and the front band, it is ok. what do you thing it could be???? regards.
RodrigoVolpato is offline
post #217 of 283 Old 12-01-2014, 05:36 PM
mbossy123
electric window doesnt work
another way to fix the electric window problem
i had a rear window in a new to me 98 zj that was taped to stay up and not connected to the regulator that was supposed to move it up and down. Found on Jeepforum from another reader that the motor could be seized up but not so bad that you couldn't fix it. The fix is to remove the door panel, locate the motor for the electric window, and then while pushing the button on door panel that moves window up/down fully one way or the other, gently bang on the motor with a hammer, after a few whacks from me i heard the motor moving, and tested to make sure it worked in both directions. Can't remember for sure but might have to remove the window regulator assembly to get at motor, either way a few good whacks got motor going. After that, moved window into track, tightened everything up in door and vavoom, was fixed. Window closed, opened, and acted as it should regularly. Theory has it that the grease the motor has on it can gum the motor up if you dont use it that regularly. Great fix, found it here from another poster.
mbossy123 is offline
post #218 of 283 Old 12-10-2014, 03:18 PM
89warwagon
1989 XJ Cherokee
Are all the links dead to these common fixes or is it just my computer?
89warwagon is offline
post #219 of 283 Old 12-10-2014, 03:33 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yes, links appear to be dead.
It looks like when this thread was deleted and revive the links got eaten by the url shortener. If I have time later I may be able to clean things up. Or Uni or a mod could.
kg6mov is offline
post #220 of 283 Old 12-10-2014, 11:16 PM
89warwagon
1989 XJ Cherokee
I would be forever in your debt if you could get the links working.
post #221 of 283 Old 12-11-2014, 01:54 AM
Uniblurb
Uniblurb's Avatar
Here's another of the exact same thread by Jason with live links. Just no comments with live links in additional posts behind his original write-up. The last link in his below MIA post/thread will take you right back to the beginning of this thread with many dead links.
https://www.jeepforum.com/forum/f13/s...l#post24142002
If you do run into a 'no page found'/dead-end link somewhere exit out of it. Then w/o clicking on the link itself drag your curser from right to left highlighting it > copy > paste into your browser search box or google, hit search, and it should come up as the 1st link/info you can click on. This only works if the page can still be found or is still there. Good luck.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #222 of 283 Old 12-11-2014, 04:16 PM
89warwagon
1989 XJ Cherokee
Thank you
post #223 of 283 Old 12-11-2014, 07:02 PM
Uniblurb
Uniblurb's Avatar
You're welcome and there are some useful links in this thread which hope they help.
Uniblurb is offline
post #224 of 283 Old 12-24-2014, 11:20 AM
Jeepheryj1993
Why does my 1993 jeep warngler run but idle rough and then when I go to crank it again it won't crank it will only spin over?
Jeepheryj1993 is offline
post #225 of 283 Old 12-24-2014, 11:28 AM
Jeepheryj1993
