Common ZJ Problems / Tutorial On How To Fix Them - Page 14 - JeepForum.com
 1Likes
post #196 of 283 Old 10-06-2014, 10:24 PM
WeRNothiNg
I have one for ya. My headlights will only come on if I hold back on the dimmer switch. I have power in the PDC, and I have replaced the switch. I swapped the relay with the one for the cigarette lighter because I knew it was working with no luck. I am going to try a new dimmer switch tomorrow. I also noticed that my flashers work, but only one side flashes(L or R) and it alternates. I will turn them on and only the left will flash, the next time it will be the right. Being as the flashers are part of the dimmer swith, it seems legit. IDK, but I am about to lose my mind on this one. Please help!
WeRNothiNg is offline
post #197 of 283 Old 10-07-2014, 04:56 AM
LouC
2007 WK
Replace the dimmer switch, I had to about 7-8 years ago on our '98 because when I would switch from high to low, the lights would go out until I clicked it a second time. Also same problem with the hazard flashers. Switch was about 100 bucks, not too hard to install.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #198 of 283 Old 10-07-2014, 01:29 PM
WeRNothiNg
A friend of mine owns a junk yard, and let me get any parts off I needed off a jeep he had on the lot for free. I got the dimmer switch and when I removed the old one I immediately seen the problem. The wiring harness had 2 connectors that had popped out of p[lace. I popped then back in and everything works great.
post #199 of 283 Old 10-07-2014, 01:32 PM
Bear304inc
Tyre to solder where you can.
Bear304inc is offline
post #200 of 283 Old 10-07-2014, 01:39 PM
WeRNothiNg
no soldering to be done. The metal clip popped out of the plastic plug.
post #201 of 283 Old 10-07-2014, 06:24 PM
Bear304inc
I gotcha, I know on the switch itself there are many write ups for resoldering the weak factory soldering points.
post #202 of 283 Old 10-08-2014, 07:22 PM
WeRNothiNg
I agree. I have read this as well. I have an extra dimmer switch now, so I will likely turn the extra into a midnight project and see what I can come up with. I have never soldered on any car switches, but I have computer motherboards, and video cards.
Should be simple enough
post #203 of 283 Old 10-22-2014, 02:33 PM
G2offroad
I have an issue with the instrumental panel. The thing does not turn on at all. As if the zj was off no info. But the light inside of it comes on and so do the blinkers hell it even tells me the outside lights are on. But no speed, temperature, or rpms. I now own 3 instrumental panels and the plug is receiving current. What else could it be? Any thoughts.
G2offroad is offline
post #204 of 283 Old 10-22-2014, 04:21 PM
Matta94GCL
2005 KJ Liberty
Hi, how are you? Can you provide more specifics of what you're dealing with? You're talking about the dash panel, not the bcm, right? It looks like you've tried swapping in a new one or a jy replacement, right? How have you verified the current, with a test light or a multimeter? I would like to help you if I can, but I'm still a little unclear about what isn't working. Pm me if you want. I'm working, but I get a few minutes to check my stuff periodically.
Matta94GCL is offline
post #205 of 283 Old 11-19-2014, 04:43 PM
jammer9
clicking&knocking sound
we have a 1998 grand Cherokee it always had a clicking but now has a knock witch gos away as soon as you give it a little fuel.I tried to pine point were it is coming from but cant findit. sounds like a diesel truck.No coolant leaks,no disappearing coolant,no milky oil. do you have any suggestion.Also no misfiring.
jammer9 is offline
post #206 of 283 Old 11-19-2014, 04:51 PM
kg6mov
Hears the voices
kg6mov's Avatar
That sounds like it has nothing to do with this thread, maybe try starting a new thread and you'll get more visibility.
It also sounds like something that would be easier to diagnose if we knew what engine you have. It could just be normal 4.0 lifter tick, but thats not a problem on the V8 . . .
kg6mov is offline
post #207 of 283 Old 11-19-2014, 05:10 PM
jammer9
jammer9 is offline
post #208 of 283 Old 11-24-2014, 12:30 PM
spawn00001212
my jeep is under heating.i changed water pump and thermostat
spawn00001212 is offline
post #209 of 283 Old 11-24-2014, 12:34 PM
spawn00001212
my jeep zj under heats after i changed thermo twice and water pump
post #210 of 283 Old 11-24-2014, 12:43 PM
spawn00001212
do anyone know why my jeep is under heating? I also changed the water pump and thermostat.Thats when it started.and my heat is low.first time owning a jeep cherokee laredo 1997 4x4 HELP!!!!its cold
