Clunk in transmission - JeepForum.com
post #1 of 7 Old 07-02-2019, 10:04 AM Thread Starter
KiloWatts
KiloWatts's Avatar
Had some transmission work done last year. They said they tightened the bands. Ever since, there has been an audible clunk when I let go of the gas. I've ignored it for a while but it might be getting louder. Is there a fork or something that 'snaps' back when letting off the gas? Just trying to get an idea of what I might tell the trans experts if I need to have something adjusted. It's a 42RE. Axle is Dana35C.
1996 4.0 L6 RWD
KiloWatts is offline
post #2 of 7 Old 07-02-2019, 02:09 PM
pigmeatstrip
Excess lash in the differential ring and pinion could be making a clucking noise throughout the drivetrain.
pigmeatstrip is offline
post #3 of 7 Old 07-02-2019, 04:38 PM
FlamingRain
I actually have had the same thing on mine ever since I had the shift kit installed on my ZJ, I think it has something to do with the higher line pressure causing it to upshift even though I let off the gas, but I'm not totally sure if that's standard operation. It's not that bad on mine but definitely noticeable.
2wd can really get you places you can't get out of without 4lo. - Ratmonkey
FlamingRain is offline
post #4 of 7 Old 07-06-2019, 03:40 PM Thread Starter
KiloWatts
KiloWatts's Avatar
Seems to be getting louder. There's a light clunk when I hit the gas, and then another immediately after I come to a complete stop. Sounds like it's coming from under middle of the vehicle, quite close to the cabin floor. Perhaps closer to the rear of the transmission area. (42RE, 4.0)
1996 4.0 L6 RWD
post #5 of 7 Old 07-06-2019, 05:51 PM
nulspace
Have you checked your transmission mount? When they go bad this also occurs.
nulspace is offline
post #6 of 7 Old 07-06-2019, 06:49 PM Thread Starter
KiloWatts
KiloWatts's Avatar
It's trashed. I'll replace that soon.
First I'm going to check my rear passenger control arm bolts, since I've isolated it to that general area. I replaced all my rear control arms a couple weeks ago, along with sway bar links and bushings. It's possible I didn't cinch down one of those bolts. This kind of thing is so tough because it's such an intermittent noise, but it does seem to happen when there is a load on the suspension. Ie: It clunks once on takeoff, and clunks once when coming to rest, then periodically if there's a particularly rough shift. (which is why I initially suspected transmission)
1996 4.0 L6 RWD
post #7 of 7 Old 07-07-2019, 11:59 AM Thread Starter
KiloWatts
KiloWatts's Avatar
As I suspected it was a rear upper control arm bolt. I tightened it down and everything is quiet again. 🙂
1996 4.0 L6 RWD
