Climate control fans not working - JeepForum.com
 1Likes
post #1 of 20 Old 03-15-2020, 08:56 AM Thread Starter
tjx0116
I've got a '98 Jeep Grand Cherokee 5.9 Limited. In turning on the heat the other day, no air came through the vents.
I hear the mechanism in the back making a noise when I change the location of the air flow, but no air comes through (no matter the setting combinations). I do notice that when I am driving fast, the fan speed is on "Hi", and the climate control unit is set to ventilation as opposed to "recirc", a very small amount of air can be felt through the vents.
Does anyone know what could be the issue here? Do I need to replace the climate control unit? Thanks!
tjx0116 is offline
post #2 of 20 Old 03-29-2020, 02:01 PM
97ComptonZJ
It’s most likely your blower motor resistor up underneath the passengers side dash! Mine is doing the same thing and if you have automatic climate control then be prepared to pay well over $100 for the resistor! If you have manual climate control then the part is only about $8!
97ComptonZJ is offline
post #3 of 20 Old 03-31-2020, 11:02 AM Thread Starter
tjx0116
Thanks a lot for your suggestion! I'm going to try to get out there today, remove the resistor, and test it with a multi-meter. I'll let you know what I find.
tjx0116 is offline
post #4 of 20 Old 03-31-2020, 12:34 PM
jtec
jtec's Avatar
2014 JK Wrangler
first which system look diagrams below?
that will aid in resistor selection.
Check PDC fuse #7 a 40amp, one of the big ugly ones.
jtec is offline
post #5 of 20 Old 04-01-2020, 05:08 AM Thread Starter
tjx0116
In your diagram, my Jeep has the bottom system.
If it was a fuse, wouldn't the entire climate control system not work?
tjx0116 is offline
post #6 of 20 Old 04-01-2020, 05:49 AM
jtec
jtec's Avatar
2014 JK Wrangler
NO
wouldn't it have been easier faster to check fuse than type a question?
Let me get the diagram again.... knowing which controller helps selecting diagram
TheBoogieman likes this.
jtec is offline
post #7 of 20 Old 04-01-2020, 06:07 AM
jtec
jtec's Avatar
2014 JK Wrangler
no speed control and no HIGH blower speed?
jtec is offline
post #8 of 20 Old 04-01-2020, 07:34 AM Thread Starter
tjx0116
No matter what speed the blower is set to, no air comes through the vents.
tjx0116 is offline
post #9 of 20 Old 04-01-2020, 11:06 AM
jtec
jtec's Avatar
2014 JK Wrangler
first how did that fuse check out?
Next do you have and Can you use a DVOM, test light and wiring diagrams?
jtec is offline
post #10 of 20 Old 04-01-2020, 02:13 PM Thread Starter
tjx0116
Would fuse #7 be "40A BLOWER MOTOR"?
tjx0116 is offline
post #11 of 20 Old 04-02-2020, 08:21 AM
jtec
jtec's Avatar
2014 JK Wrangler
See attachment -
jtec is offline
post #12 of 20 Old 04-03-2020, 08:32 AM Thread Starter
tjx0116
See attachment -
Thanks for the diagram! The fuse looks good to me -- see for yourself:
tjx0116 is offline
post #13 of 20 Old 04-03-2020, 03:07 PM
jtec
jtec's Avatar
2014 JK Wrangler
jtec is offline
post #14 of 20 Old 04-04-2020, 06:02 PM
jcjunkie
jcjunkie's Avatar
Why don't you.make a jumper and power on the blower to see if it works or not.
98 5.9
jcjunkie is offline
post #15 of 20 Old 04-07-2020, 09:35 AM Thread Starter
tjx0116
How would I do that?
Also, would a multi-meter help in determining if the blower resistor isn't working?
tjx0116 is offline
