Cleaning up an aftermarket audio mess... - JeepForum.com
post #1 of 9 Old 01-15-2011, 08:06 PM Thread Starter
loudog3114
96 Zj limited with infinite gold...
At some point, this thing had an aftermarket head unit in it, and an aftermarket amp. There is wiring all over the place indicating so. When I bought it, it appeared to be all wired back to stock with the stock head unit and amp wired. However, I dont get any sound out of any front speakers. I checked behind the head unit, and there is a ground (black) wire coming from the wiring harness that is cut, taped, and dangling - not connected to anything. Then on the plug for the head unit I noticed one pin isnt connected to anything. I wondered if that was for the ground so I tested it but all that did was make the audio output much quieter; it still didnt put any audio to the front speakers.
So my question is, what am I missing that would make the 4 front speakers not work? Is it possible the amp just isnt putting power out to the front 4 any more?
92 YJ, 35's, 6", Locked
97 Honda CBR1100xx
08 336XI
loudog3114 is offline
post #2 of 9 Old 01-15-2011, 08:29 PM
Dyn0mitemat
Dyn0mitemat's Avatar
The black is ground, it should be connected to a bolt on the back of the stock headunit to ground it. I'd reconnect that.
And can you elaborate more on:
What color wire was this? Or which spot in the plug/harness is it?
Dyn0mitemat is offline
post #3 of 9 Old 01-15-2011, 08:55 PM
aircruiser
aircruiser's Avatar
on the factory HU, the ground actually has a little slip on connector that slips over the tab on the back of the HU
aircruiser is offline
post #4 of 9 Old 01-16-2011, 02:12 PM
Canyon411
If the system was restored back to stock, the lf, rf, lr, rr speaker leads coming from the head unit should all be connected to the factory harness in the dash. The infinity amp under the seat uses high-level input (speaker level) rather than rca's so make sure that the factory harness under the seat has all four speaker leads coming in. Use the colors in the dash as a map and find the same in the rear and follow the colors to be sure they are connected and not cut and taped off somewhere out of site. Also check to see if the factory speaker wires in the front doors are currently connected to the speakers. They may have been disconnected, taped off, and bypassed with new speaker wire run from the previous owners aftermarket amp. Hopefully one of these ideas is the right one!!
Canyon411 is offline
post #5 of 9 Old 01-20-2011, 02:19 AM
Smedly
Knew I had this page saved somewhere...
http://crutchfield.custhelp.com/app/...tail/a_id/5763
It ID's all the factory wiring for Infinity in a 96 ZJ
Hope it helps
.______
/l ,[____],
l----I---0lllll0-
()_) ()_)--o-)_)
Smed
Smedly is offline
post #6 of 9 Old 01-20-2011, 07:35 AM Thread Starter
loudog3114
Thanks a ton. I havent brought myself to sit out in the cold and look at this thing again yet so once i do ill repost.
97 Honda CBR1100xx
08 336XI
post #7 of 9 Old 01-20-2011, 10:13 AM
Mike2909
Mike2909's Avatar
I had to rewire my original head unit, I believe this pin you connected will be the mute.
Mike2909 is offline
post #8 of 9 Old 01-20-2011, 01:40 PM Thread Starter
loudog3114
all black wire and pin #7?
So its useless then in otherwords, or is there a mute button somewhere?
97 Honda CBR1100xx
08 336XI
post #9 of 9 Old 01-20-2011, 03:07 PM
Mike2909
Mike2909's Avatar
The mute will be connected if you have a cellphone installed in the Jeep, the radio would mute automatically when you get an incoming call.
Try this link
http://www.installdr.com/installdocs...PDF/533013.asp
it should explain and help you.
Mike2909 is offline
Did I just mess up nashmd454 ZJ Grand Cherokee Forum 20 02-05-2008 09:09 PM
What did I mess up this time? JayIV ZJ Grand Cherokee Forum 10 01-30-2008 04:51 PM
Why did this mess up my... Casper4x4 ZJ Grand Cherokee Forum 13 12-25-2007 07:53 AM
Infinity audio upgrade from base audio? Ewout_vB ZJ Grand Cherokee Forum 10 07-23-2007 04:13 PM
How bad did I mess up? slaterny ZJ Grand Cherokee Forum 14 12-14-2004 09:12 AM
