Clading molding - JeepForum.com
 1Likes
  • 1 Post By JonMopar
post #1 of 13 Old 11-24-2021, 10:24 PM Thread Starter
papitt
Clading molding
So 2 questions where is the best place to get new .. CLADDING MOLDING White Plastic strips to hold the cladding in place ..These strips are a white plastic & seem to be about 10 inches long .. But my claddings seen to keep getting loose .
...............& It seems like some of you Guys told of the best .. Chemical stuff to wipe onto your side molding claddings to bring back their factory colors.
I have 2 Jeeps ZJ 's & A 2000 DODGE pick-up. D2500 . & I'D Like for someone to tell us of a cheaper
papitt is offline
post #2 of 13 Old 11-24-2021, 10:26 PM
LagunaH1
Junior Member
I search eBay regularly for cladding but have not yet been able to find anything for my 95 ZJ limited
Very interested to hear if others have good ideas…..
Sent from my iPhone using Tapatalk
LagunaH1 is offline
post #3 of 13 Old 11-24-2021, 10:33 PM
speedbrake
1994 ZJ
If the factory color you're referring to is the gray cladding on the non-Limited models, then Carworx Refinish Restorer is the stuff you want.
speedbrake is offline
post #4 of 13 Old 11-24-2021, 11:42 PM
JonMopar
Nothing will likely be a permanent fix, because the cladding started to fade from day 1, but I have good luck with Trim Shine (aerosol can). It lasts and is easy to apply. They sell it at Wal-mart
speedbrake likes this.
98 Laredo ZJ 4L -3.73, 5.9 "ultrastar" rims, slotted brakes, Dynomax turbo, CAI.
JonMopar is offline
post #5 of 13 Old 11-25-2021, 05:53 AM
yjsaabman
1930 CJ2
One of the keys to the cladding mounting strips is to know how to properly remove the cladding from them. IIRC you pry out from the bottom of the cladding and then it lifts up off the top. It is a rather delicate design and can get damaged easily in minor impacts. I'll have to look through my parts from the right side of mine, but there are some differences in the mounting strips based on side of the Jeep and installation location. IIRC there's only one broken strip on the right side set that came off mine. I've had the left side off, but put it all back on because I didn't get around to opening up the wheel arches or doing the built in slider on that side yet. Those mounting straps seem like a good candidate for 3D printed replacements. Checked Thingiverse quick but didn't see anything yet.
Sent from my SM-G970U using Tapatalk
yjsaabman is offline
post #6 of 13 Old 11-25-2021, 10:22 AM
MaintMech
MaintMech's Avatar
Cladding fasteners:
Clipsandfasteners Inc 50 Truck Door Trim Panel Clips For Grand Cherokee & Dodge | eBay
Auveco Products - Automotive, Industrial and Specialty Fasteners
Northland Fasteners - Best Selection of Automotive Fasteners
Good luck!
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #7 of 13 Old 11-25-2021, 12:04 PM
yjsaabman
1930 CJ2
Those are for the interior panels. OP is asking about the mounting strips for the exterior cladding along the bottom of the doors.
https://www.ebay.com/itm/93-98-JEEP-...-127632-2357-0
post #8 of 13 Old 11-25-2021, 09:24 PM Thread Starter
papitt
Yes I need the long white strips .. & That Stain replenisher looks awesome also.
.....Thanks .
papitt is offline
post #9 of 13 Old 11-26-2021, 11:12 PM
phacemeltar
I saw some over at deadjeep.com
phacemeltar is offline
post #10 of 13 Old Yesterday, 02:46 PM
StPaul59
Heat gun..
StPaul59 is offline
post #11 of 13 Old Yesterday, 04:32 PM
yjsaabman
1930 CJ2
That ebay link I posted is new ones, and there are links to to the end pieces specific to each side, etc in that link. The only caveat is that they are $20+/ea and $17-ish/ea depending on position.
post #12 of 13 Old Yesterday, 08:27 PM Thread Starter
papitt
St Paul what are you meaning HEAT GUN.
.. Use heat gun to make these part function better.?
papitt is offline
post #13 of 13 Old Today, 12:40 AM
JonMopar
I think he might mean using a heat to bring back the cladding’s appearance...?? It’s a common trick to for faded plastic but the heat gun method can yield blotchy uneven results, shiny spots, and there’s also the risk of damage (if you’re not careful, you may melt or deform them. Or at the very least, change the surface texture).
JonMopar is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
