Changing fuel pump tomorrow... - JeepForum.com
post #1 of 13 Old 09-21-2006, 04:43 PM Thread Starter
spros95jeep
I just picked up my fuel pump for my 95 I6 and I was wondering if I need any special tool(s) to remove the old one. This is the first time for me doing a fuel pump. I have everything I need to drop the tank. Just wondering about the actual removal of the pump. Thanks in advance.
spros95jeep is offline
post #2 of 13 Old 09-21-2006, 05:26 PM
eltj
Its pretty easy on the ZJ. The ring on top is sometimes a bear to get off but once that is off it just slips right out. No special tools needed.
eltj is offline
post #3 of 13 Old 09-21-2006, 05:54 PM Thread Starter
spros95jeep
Will channel locks work ok to remove the ring?
post #4 of 13 Old 09-21-2006, 05:57 PM
-Joe-
-Joe-'s Avatar
Make sure you put the new pump back in facing the same direction as the old.
Hopefully you got an entire pump housing and new gasket as well.
A big screwdriver and a few taps on the ring will get it off pretty easy. Its like 6-7 inches in diameter
I would go ahead and replace the worm clamps on the fill tubes while your there.. mine were pretty much rusted thru. (at the tank and at the top of the fill hoses)
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 13 Old 09-21-2006, 06:12 PM Thread Starter
spros95jeep
Yeah, I bought the whole assembly ($350) and I have replacement clamps too.
post #6 of 13 Old 09-21-2006, 06:17 PM
-Joe-
-Joe-'s Avatar
The ring sort of sits down into the tank.
Heres a picture with the locking ring removed..
- Joe -
-Joe- is offline
post #7 of 13 Old 09-21-2006, 06:23 PM Thread Starter
spros95jeep
Thanks for the pic. Very helpful. Heres the pump I have. Did your new one look like this? Hope the link works.
http://napaonline.com/masterpages/NO...c+In-Tank+Type)
post #8 of 13 Old 09-21-2006, 06:25 PM
-Joe-
-Joe-'s Avatar
That link doesnt work.
I only replaced the pump itself and reused the old housing.
They changed the fuel pump in 95 so one for a 94 or 96 wont fit.
- Joe -
-Joe- is offline
post #9 of 13 Old 09-21-2006, 06:34 PM Thread Starter
spros95jeep
Hope one of these links work. This is what the new one looks like.
post #10 of 13 Old 09-21-2006, 06:38 PM
-Joe-
-Joe-'s Avatar
The only difference that I know of is in 95 theres only 1 fuel line coming from the pump.
Its a different design though, the one I pulled out was pretty much enclosed while that one has the top open a little. Shouldnt matter as long as you got 1 supply line and the right electrical connector.
I dont think i kept any pictures of it anywhere.
- Joe -
-Joe- is offline
post #11 of 13 Old 09-21-2006, 06:43 PM Thread Starter
spros95jeep
The instruction sheet said it may be different looking from the original but will work fine. When I first looked at it I was like, WTF? Is this really gonna be ok with all of these wires sitting in gas? What if one shorts out or something? They say it will be fine. I hope so.
post #12 of 13 Old 09-21-2006, 06:46 PM
-Joe-
-Joe-'s Avatar
An electric motor pumping gas, who would have thunk..
I would think napa would get you the right part.
I wouldnt toss the old pump though. Might be able to save some of the parts for later. Just the pressure regulator is like $40-50, and even though jeep says its not replaceable it is. Not exactly easy to get to, but you can.
- Joe -
-Joe- is offline
post #13 of 13 Old 09-21-2006, 06:51 PM
Swamp Boy
Swamp Boy's Avatar
If you have factory tow package thats going to be a biotch to get off.. Dont give up....
Just another soccer moms Grocery getter....
Swamp Boy is offline
New aftermarket high quality fuel pump? second pump in 3 years?!!!!? SPL Tech ZJ Grand Cherokee Forum 8 11-02-2010 05:12 PM
Changing Water Pump on 02 GC - 4.7 jj99 WJ Grand Cherokee Forum 5 06-18-2010 09:45 AM
Changing the OIL PUMP.... nat441 ZJ Grand Cherokee Forum 2 03-24-2008 11:21 PM
Changing water pump 2000 GC ron4488 ZJ Grand Cherokee Forum 1 10-09-2005 06:42 PM
Changing Out A Water Pump CATMAN2 ZJ Grand Cherokee Forum 1 10-20-2003 04:57 PM
