Cant Get Lugs Off - JeepForum.com
post #1 of 22 Old 02-21-2010, 09:37 PM Thread Starter
ZJ-Soldier
Cant Get Lugs Off
Ive tried everything, impact wrenches, torch, is there anyway i can cut the damn bolt out or grind it off from the back, im getting new wheels and tires so thats not a big deal, i just need to know how to get the damn things off
ZJ-Soldier is offline
post #2 of 22 Old 02-21-2010, 09:39 PM
lateralus3
lateralus3's Avatar
1994 ZJ
a breaker bar with a long piece of pipe on it
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #3 of 22 Old 02-21-2010, 09:48 PM
soul_Less
1994 ZJ
^ agree with that, and some wd40
soul_Less is offline
post #4 of 22 Old 02-21-2010, 09:53 PM
flyboy14295
flyboy14295's Avatar
And if it's a reputable name tool, and you do break it, just warranty replace it
WJ. 4.Slow I6. The Underdog
2" Teraflex BB, 265/70R16 BFGoodrich TA KO's, JKS Adjustable Track Bar, JKS HD Tie Rod, Rusty's Tow Hooks, Block Heater, CB
New York City EMS
Originally Posted by LoneJeeper View Post
I came into this world via broken rubber, i'm not going out the same way.
flyboy14295 is offline
post #5 of 22 Old 02-21-2010, 10:10 PM
Virmagicus
Virmagicus's Avatar
Sounds like some are stripped already eh? If that's the case, post back we have all kinds of tricks.
Jeff
Virmagicus is offline
post #6 of 22 Old 02-21-2010, 10:28 PM
Marctwayne
Marctwayne's Avatar
I know it sounds like a rookie mistake but I've done it... So make sure the impact you are using is set at its highest setting. Your compressor is at full pressure and the regulator is wide open. Get a good penetrating lubricant WD40 is not your best option. If the impact won't do it leverage is you best weapon. Heating up the nut is hard to do without in turn heating up the bolt as well. Cutting or grinding the nuts off is a hard call. If it comes to that cut or grind at the base of the nut only as far as you need to then break the bolt off. It will save you time and limit the destruction or your wheels and such. I guess you could try heating up the nut\bolt and see if you could break it while hot but I'v never tryed it and you may introduce to much heat into the rotor and cause it to warp.
-- Marc Wilson -- 85 CJ7 Called Buster, Why? The wife likes to yell out the door "Are you done fix'en buster's bits yet"?
Originally Posted by my-jeep-earl View Post
It does look alot better when the Jeep is "ugly side up" though! :hahaha::teehee:
Marctwayne is offline
post #7 of 22 Old 02-21-2010, 10:51 PM
Greengc4x4
Greengc4x4's Avatar
Pound a socket over the lug nut. That has nver failed me. Matter of fact. The PO stripped the locking lug nuts on my wheels. So today I had to use this method to remove them. Works like a charm.
Greengc4x4 is offline
post #8 of 22 Old 02-22-2010, 11:55 AM
southernmudzj
second this, ive had to do the same thing before lug was stripped so had to take a bfh and a smaller socket and beat it on, then the lug came off
96 zj. 31x10.50 uniroyal awts. 2.25 bb rough country 9000 shocks. rustys transmission crossmember
cobra radar detector future mods:rustys 5.5 long arm kit and smittybilt xrc8
southernmudzj is offline
post #9 of 22 Old 02-22-2010, 11:57 AM
TDHofstetter
Is there enough room to get a nutcracker on it? That's a hard tool to argue with.
TDHofstetter is offline
post #10 of 22 Old 02-22-2010, 12:31 PM
JesseOR
Leverage, leverage, leverage! That is all you need, if they aren't stripped.
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #11 of 22 Old 02-22-2010, 01:29 PM
LordHobbit
LordHobbit's Avatar
use anti-sieze when putting on the new lugnuts.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #12 of 22 Old 02-22-2010, 04:46 PM
rooster51
rooster51's Avatar
That will change the proper torque rating, but a good idea if you know the proper NEW torque rating
Terry
rooster51 is offline
post #13 of 22 Old 02-22-2010, 05:03 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Don't talk about my wife behind my back man.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #14 of 22 Old 02-22-2010, 05:05 PM
dels383ta
Go and get your self a set of reverse cut sockets, they will get them off the harder you turn the more it bits, and it will grab onto a stripped nut also and they work awesome on lock nut(for those that lost the key).
Rubicon Express 3.5",5.2 Swap,LP10K Superwinch/7/16 syn line,RE Adj Track Bar and Drop Bracket,Hercules Trail Digges 33x12.50, D Windows ,HI Lift,Custom built Rad Support,D44 Rear w/ spool,HP30Aussie Locked , Alloy USA Tube seals, Custom rear bumper,More to come.
dels383ta is offline
post #15 of 22 Old 02-22-2010, 06:20 PM Thread Starter
ZJ-Soldier
thanks lots of great ideas, hopefully my wheels and tires will be here by this weekend and ill be able to put them to use
Anti Seize on lugs inlinegrand6 ZJ Grand Cherokee Forum 18 02-20-2010 11:07 PM
ZJ Wheel lugs and Transmission amonostereo ZJ Grand Cherokee Forum 9 06-30-2009 05:11 AM
moved yoke lugs how do i ? gaz38uk ZJ Grand Cherokee Forum 8 05-30-2008 11:31 AM
engine lugs when humid out ? jeepunlimited ZJ Grand Cherokee Forum 2 09-07-2007 01:48 PM
Lugs? Magikal_ZJ ZJ Grand Cherokee Forum 1 06-18-2007 08:18 AM
