cant get jeep out of 4wd p/t - JeepForum.com
post #1 of 10 Old 04-01-2008, 09:29 AM Thread Starter
LaradoChicka
Guest
hi im new to the forum and i just recently got my jeep which is a 99 grande cheroke larado.. My brother decide he wanted to mess around with the 4wd after changing the breaklight bulb, without reading the owners manual and it wont come out of 4wd part time.. i've read the manual over and over again and and it says nothing about going from 4wd to 2wd... if someone could help me that would be great.. i apolagize if this is in the wrong thread area i just want to get my jeep back to where it was before my jack off of a brother touched it
LaradoChicka is offline
post #2 of 10 Old 04-01-2008, 09:43 AM
CMARJEEP
CMARJEEP's Avatar
take the lever and shove it back to the 2wd position. that is all there is to it. but dont drive around at all with it in part time 4wd. it could damage your driveline if you do it for very long. you might have to drive a few feet for it to disengage. just dont take sharp turns or drive far. if that doesnt work then try going in reverse for 30-50 ft. if that doesnt work then the linkage between the shifter and the tcase is messed up and has to be readjusted.
btw... is the "grande" cherokee the special edition full size jeep that i have been hearing about?
CMARJEEP is offline
post #3 of 10 Old 04-01-2008, 09:48 AM Thread Starter
LaradoChicka
Guest
its not that i cant get th lever to go back up it goes up just cant get the jeep to disengaed form 4ws pt
[/QUOTE]btw... is the "grande" cherokee the special edition full size jeep that i have been hearing about?[/QUOTE]
lol im not really sure ill post pics of my jeep shortly
post #4 of 10 Old 04-01-2008, 09:56 AM Thread Starter
LaradoChicka
Guest
forgot to ask how do you readjust it?
post #5 of 10 Old 04-01-2008, 10:00 AM
CMARJEEP
CMARJEEP's Avatar
so did you try everything to get it to disengage? to readjust it you have to get under the jeep and loosen the linkage and readjust it.
sometimes it just takes a few tries to get it to disengage.
CMARJEEP is offline
post #6 of 10 Old 04-01-2008, 10:35 AM Thread Starter
LaradoChicka
Guest
i've tried numerious times and still nothing wont even o into 4wd ft, N, or 4wd lo... think it could be bound up? if thats the case how much would be to fix that
post #7 of 10 Old 04-01-2008, 07:31 PM
NEp8ntballer
I'm trying to figure out if this is an april fools thread or not. but just take the heel of your palm to the back of the transfer case shifter and give it a push. using the handle to put it back is for suckers.
NEp8ntballer is offline
post #8 of 10 Old 04-01-2008, 07:54 PM
jdubbs107
lol im not really sure ill post pics of my jeep shortly[/QUOTE]
no, it was made in mexico. and at starbucks grande is mid-size suv coffee
jdubbs107 is offline
post #9 of 10 Old 04-02-2008, 01:16 AM
Swamp Boy
Swamp Boy's Avatar
IF this is not an April fools joke .. I would suggest getting under it and seeing if your shifter linkage hasnt popped off .. It has been known to happen..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #10 of 10 Old 04-02-2008, 01:42 AM
ajmorell
ajmorell's Avatar
Seems there is a problem with the linkage to me. What you should do is crawl under there and watch what is happening while someone else is shifting the transfer case through its ranges. It should be pretty obvious if it is or isn't doing it's intended job.
ajmorell is offline
Couple repairs planned for this weekend, will my Jeep be right by monday jeep gods ?? cherokeeghost ZJ Grand Cherokee Forum 1 11-12-2008 11:53 AM
