Can someone tell me what these wires are for? - JeepForum.com
 5Likes
post #1 of 17 Old 04-09-2019, 04:05 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Dear JeepForum, I keep working on my new to me 1997 Grand Cherokee... under the rear seat, I found this wiring harness all hacked and slashed... seems like it was cut off then reattached, it beats me why anybody would do this, some of the wires are joined together with masking tape... (gotta love the PO)...
I also found my ABS light was on, the bulb was missing from the dash (I kinda expected this) when I went under the car to take a look I found the ABS sensor cables hacked as well, I believe the ABS wires connect here from the rear wheels, but there is only one connected and both are cut off.
Anyway, please look at the pictures, I will try to restore the ABS system, if I can't then I may remove it altogether, but I'd like to try and save it... in the meantime, I need to know what these wires are for.
Thanks!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #2 of 17 Old 04-09-2019, 04:17 PM
kg6mov
Hears the voices
kg6mov's Avatar
Looks like somebody deleted the factory infinity amp.
GChief likes this.
kg6mov is offline
post #3 of 17 Old 04-09-2019, 04:26 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Thank you! there is an aftermarket radio installed, it works, not sure if it is powering all speakers...
Fernando is offline
post #4 of 17 Old 04-09-2019, 04:48 PM
kg6mov
Hears the voices
kg6mov's Avatar
The taped together sections are likely acting as an amp bypass, that's a common cheap way to do it. If you're lucky the stock wiring has been abandoned and they ran new cables cleanly.
I'd bet more on the former.
This is from a 98 fsm, and should match a 97. You should be able to match the colors and decipher how it's been setup.
kg6mov is offline
post #5 of 17 Old 04-09-2019, 08:27 PM
1stZJTRUCK
1stZJTRUCK's Avatar
Yes that is where my amp was located also the wires to the fuel tank and rear abs
1stZJTRUCK is offline
post #6 of 17 Old 04-09-2019, 08:31 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
As for "removing the ABS", If you cannot fix it, just pull the bulb. No need to remove anything, as when the amber bulb is lit, it is basically operating like it never had ABS in the first place. If it is a red brake light, it is a hydraulic issue or e-brake switch.
Rick
Cutlass327 is offline
post #7 of 17 Old 04-09-2019, 10:31 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Attachment 3817111
Thank you so much... I will test if all speakers work... I guess the amplifying comes from the new radio now?
Do you know by any chance where the ABS computer is located? Thanks!!
Fernando is offline
post #8 of 17 Old 04-10-2019, 12:16 AM
kg6mov
Hears the voices
kg6mov's Avatar
On a 97 the ABS is part of the PCM IIRC?
Yup, the wires for the speakers at the radio are the same with or without the amp, so with a bypass it's just feeding the doors off the new head.
Not great, but better than a broken infinity amp I guess.
kg6mov is offline
post #9 of 17 Old 04-10-2019, 10:30 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Thank you so much for the help... I guess the stock radio is just a faceplate at the front and the amplifier drove the stock speakers? I know nothing of car audio... I wonder if the radio was louder when the amplifier was working
Fernando is offline
post #10 of 17 Old 04-10-2019, 11:06 PM
ZeeJay1997
ABS computer on a 97 is just fwd of the master cylinder
ZeeJay1997 is offline
post #11 of 17 Old 04-11-2019, 03:13 AM
Timo_90xj
Timo_90xj's Avatar
Yeap, ABS brain box is part of the HCU unit, not in the PCM.
As has been mentioned, the larger connectors are for the infinity amp, the two small connectors are for the rear ABS sensors.
***Under construction***
Timo_90xj is offline
post #12 of 17 Old 04-11-2019, 09:21 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Is it at the box where all the lines meet? I see a big wiring harness connected to it
Thank you so much!
Fernando is offline
post #13 of 17 Old 04-11-2019, 09:49 AM
Timo_90xj
Timo_90xj's Avatar
Yeap, the machined aluminum chunk with five brake lines (two in, three out) is the ABS hydraulic control unit (HCU), and the brain box is attached to it.
post #14 of 17 Old 04-11-2019, 10:24 AM
GChief
GChief's Avatar
Hate to Hi jack but this fits. Where could I find the pin out for a 95 with the Infinity system? Are they the same? Only my passenger dash and door speakers are working.
GChief is offline
post #15 of 17 Old 04-11-2019, 12:38 PM
kg6mov
Hears the voices
kg6mov's Avatar
The 95 is just different enough to hurt my brain. I don't have a digital 95, so here's transcription.
C323
1 - 16LB/RD - OUT RIGHT FRONT DOOR +
2 - 16LB/BK - OUT RIGHT FRONT DOOR -
3 - 16TN/RD - OUT RIGHT REAR DOOR +
4 - 20VT/YL - IN RIGHT FRONT DOOR +
5 - 20DB - IN RIGHT FRONT DOOR -
6 - 16TN/BK - OUT RIGHT REAR DOOR -
7 - 18GY/OR - ENABLE SIGNAL FROM RADIO
9 - 20DB/WT - IN RIGHT REAR DOOR +
10 - 20DB/OR - IN RIGHT REAR DOOR -
1 - 16WT/RD - OUT LEFT REAR DOOR +
2 - 16VT - FUSED B+
3 - 16LG/RD - OUT LEFT FRONT DOOR +
5 - 20BR/YL - IN LEFT REAR DOOR +
6 - 20DG - IN LEFT FRONT DOOR +
7 - 20BR/RD - IN LEFT FRONT DOOR -
8 - 20BR/LB - IN LEFT REAR DOOR -
10 - 16BK - GROUND
11 - 16BK - GROUND
12 - 16LG/BK - OUT LEFT FRONT DOOR
13 - 16VT - FUSED B+
14 - 16WT/BK - LEFT REAR DOOR -
GChief likes this.
kg6mov is offline
I-6 'TeamRush Upgrade' (definitive) JeepHammer Jeep CJ Forum 796 02-07-2020 08:51 PM
Running wires through a fiberglass hardtop armyRN General Jeep & Off-Road Equipment 32 01-23-2019 10:24 AM
CJ5 rear end wires pavejon Jeep CJ Forum 3 11-11-2018 07:45 AM
Wiring LED Lights into Trailer Wires markcc13 JK Wrangler Technical Forum 1 05-31-2018 07:27 PM
WK Stock Wiring Harness. Waht do the wires mean? MassWK2010 WK Grand Cherokee & XK Commander Forum 2 03-27-2018 10:36 AM
