can i run 33s on stock axels? - JeepForum.com
post #1 of 7 Old 09-18-2019, 08:58 PM Thread Starter
joev3211
does anyone know if i can run 33s on stock axels or do i need to re-gear for my 94 zj 5.2L. dana 30 in front and dana35 in the rear.
joev3211 is offline
post #2 of 7 Old 09-18-2019, 11:00 PM
jeeepguy
jeeepguy's Avatar
You can run them on the road and light trails offroad. .. it will be sluggish.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #3 of 7 Old 09-19-2019, 12:45 AM
PartyTime
PartyTime's Avatar
I have a 4.0L with 3.5” lift and stock 3.55 gears (d35c) so might not be the best comparison but im on 255/85/r16s (33x10) and it’s sluggish over 25 or 30 mphs, on some roads the speed limit is right in between gears which is annoying, and loading up with people and stuff is more noticeable too... for my 95zj a re-gear is a must but you have the V8 so maybe the extra power will make up for it (5.2 zj owners to chime in)
What about clearance, do you have a lift? For me on 3.5 inches of lift I had to move the front axle forward a little and the rear axle rearward a little to fit the tires in the wheel wells (and trimmed front bumper). I have the IRO adjustable control arms and track bars so those axle adjustments are easy to do.
As for how risky (or not risky) it is in regards to possibly breaking something (knock on wood)... I’m probably not a good resource since I don’t have any experience breaking anything so far. But I think it’s not a simple tire size limit for each axle model (d35 = 33, d44 =35) it depends on a lot of things, are you planning on getting a locker, do you do rock crawling or mudding or sand running, lead foot or feather touch on the gas, cautious or bold driver, etc....
I’m sure some people here I’ll give you some of their experiences with snapping or not snapping on stock axles.
Good luck bud!
-Party Time
PartyTime is offline
post #4 of 7 Old 09-19-2019, 07:29 AM
LordHobbit
LordHobbit's Avatar
Yes, yes you can. Should you? Probably not.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #5 of 7 Old 09-19-2019, 08:54 AM
Timo_90xj
Timo_90xj's Avatar
My 5.9 felt pretty lazy on 32s and stock 3.73 gears. Now with the 33s and 4.56 gears and some engine upgrades it feels like it should.
Friend had 33s on stock gears on his 5.2 and I didn't like it at all. Now with the 409 stroker and stock gears it's probably slightly faster than my niner on 33s and 4.56 gears.
My XJ on 3.55 gears and 31s was not fast by any means, felt down in power, hunted between gears. It was much better on 35s and 4.88 gears.
I wouldn't regear an LP D30 and/ or D35 at all - and especially not for 33s. I'd ditch those axles and bare minimum get an XJ HP D30 and a '96-'98 D44a from a V8 ZJ and regear those. If you can weld, an Explorer Ford 8.8 is another good, cheap and easy-to-find in junkyrars rear axle upgrade.
***Under construction***
Timo_90xj is offline
post #6 of 7 Old 09-19-2019, 07:23 PM
LittleFootZJ
I have 4.5Ē lift with 33s. 5.2L with 3.73 gears (D44a rear). Itís not that slow...have to turn overdrive off to get good acceleration up a hill but not that annoying to me. Plenty of power off-road. Iíve done the Miller Jeep trail with no issues. Mojave road, trails up in big bear, all no issues except with my lift. Had these for around 5 years, before that I was on 32s....everyone talks like itís horrible and I donít understand...itís not optimal but itís certainly not bad either.
Sent from my iPhone using Tapatalk
LittleFootZJ is offline
post #7 of 7 Old 09-20-2019, 02:58 AM
ZblackliZard
ZblackliZard's Avatar
Mine is on stock axles (D33,D35) 33's doing good for now. My off-road is mainly snow.
Born into Off-road, Discovering the Jeep world
ZblackliZard is offline
