A/C compressor wiring - JeepForum.com
post #1 of 8 Old 07-08-2015, 07:52 PM Thread Starter
BaileysZJ
1994 ZJ
Hello, basically I bought an A/C compressor because my compressor clutch was fried. The compressor I got was a different connection to the clutch assembly. The one that fits my jeep is a single pin where as the one I received was a double pin. Any ideas on how I can wire these to make it work? Thanks. And I'm sure someone will have questions it's a kind of confusing situation lol
BaileysZJ is offline
post #2 of 8 Old 07-08-2015, 11:01 PM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
The single pin setup gets its ground from the engine, the single wire is the power wire. More likely the double pin connector has a ground wire instead. If one of the wire is black, this would indicate that's the ground wire, that would be the one you would want to AVOID connecting the power wire to. You have a digital voltmeter? You can test this very quickly to confirm.
My only concern is if the wire connector is wrong, are you sure this compressor is the correct fit?
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, 703s injectors, Jones Exhaust A3518M-5
2020 RECOUNT
rep-tile is offline
post #3 of 8 Old 07-09-2015, 05:01 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Aftermarket comps do this all the time, for ZJ's anyway. I believe some come with an adapter harness.
Originally Posted by HighLonesome
coralman is offline
post #4 of 8 Old 07-09-2015, 10:16 AM
kg6mov
Hears the voices
kg6mov's Avatar
Since a compressor clutch is a solenoid it won't hurt the compressor if you wire it wrong. If both compressor connectors are isolated from ground it won't hurt the jeep either. One direction wil work and the other won't.
kg6mov is offline
post #5 of 8 Old 07-09-2015, 11:13 PM
rep-tile
rep-tile's Avatar
You're right if the connectors ground is isolated from the compressor it won't hurt to wire it wrong, didn't think of that. In fact in this case he would have no choice but to connect the ground of the connector to the ground of the vehicle to complete the path. He's gonna have to run some tests to find out which connector is the ground, since solenoids are polarized and the direction of current does matter.
But if the connector is grounded to the compressor and he wires it wrong, that's going to create a short and in the best case scenario pop a fuse. Therefore, to avoid.
2020 RECOUNT
rep-tile is offline
post #6 of 8 Old 07-10-2015, 03:51 PM Thread Starter
BaileysZJ
1994 ZJ
On the old compressor it looks like it grounded right to the compressor (which I tried) and it didn't work. Do you think taking it to one of the engines grounds would work better?
post #7 of 8 Old 07-10-2015, 09:33 PM
kg6mov
Hears the voices
kg6mov's Avatar
No, shouldn't matter.
Also, why did you replace the whole compressor instead of just the clutch?
kg6mov is offline
post #8 of 8 Old 07-10-2015, 11:29 PM Thread Starter
BaileysZJ
1994 ZJ
Because when I went to remove the bearing race that was rust welded on the compressor housing around the center shaft broke with it.(little too much force)
