Buying a 1997 ZJ for Overlanding - Page 3 - JeepForum.com
 1Likes
post #31 of 48 Old 06-12-2019, 12:43 PM Thread Starter
RepBolt
Originally Posted by HighLonesome View Post
this one works
https://www.ebay.com/itm/DODGE-360-M...frcectupt=true
but I had the gaskets beforehand, you can get all the ancillary stuff at rockauto
I've been looking at RockAuto for parts. Is there a one-stop-shop guide on the exact part numbers for ZJs (specifically 1997s if it's different)?
As for the maintenance I'll be doing since I picked up my ZJ, here is the list I've composed with your guys' help. Is there anything else I should get checked?
Maintenance:
- Check for leaks (rear, main)
- Replace all fluids
- Tune up
- Check exhaust system
- Oil pan gasket
- Oil pump
- New belt
- New hoses
- Transmission drain/fill and band adjustment
- New dorman pan
- New filters
RepBolt is offline
post #32 of 48 Old 06-12-2019, 01:03 PM
HighLonesome
HighLonesome's Avatar
Oil pan gasket is a bear. Heck with all you want to do, you might as well pull the motor. Then you could do the trans input seal, timing cover gasket/front main seal, rear main seal, whatever you want and easily. You'll be draining the radiator either way too.
HighLonesome is offline
post #33 of 48 Old 06-12-2019, 01:40 PM Thread Starter
RepBolt
I mean I just got my ZJ, so I mainly want to just ensure that it's healthy for road trips. I'll be going camping soon so would hate to be stranded.
I'll most likely start off with a tune up then dive into any larger issues down the road.
RepBolt is offline
post #34 of 48 Old 06-12-2019, 06:54 PM
PolkaPower
PolkaPower's Avatar
Originally Posted by RepBolt View Post
Would anybody else recommend a Hughes plenum kit and if not, what plenum kit would you recommend? I'd like to get this replaced along with my full service.
There is not other complete plenum kit. You can piece a kit together but it will be more expensive.
Sent from my BND-L24 using Tapatalk
PolkaPower is online now
post #35 of 48 Old 06-12-2019, 07:27 PM
HighLonesome
The plate and bolts are $70. You can get Felpro gaskets and intake bolts for $57 from Rockauto. That's plenum, intake and TB gaskets. All you need. Just not a fan of Hughes I guess.
post #36 of 48 Old 06-12-2019, 08:27 PM
PolkaPower
PolkaPower's Avatar
Hughes comes with a bypass hose and tb gasket too. I've done it both ways and its just less expensive and less pain in the arse to just get the kit.
You should do the valve cover gaskets too.
post #37 of 48 Old 06-12-2019, 08:33 PM
BeardyHat
BeardyHat's Avatar
I think the oil pan gasket was one of the first things I did and while it was a be of a pain, I don't think it was too terrible. Could probably be done in a day, as long as you've got the jackstands to allow the front axle to drop enough, you can wiggle the pan out.
Replacing the oil pan gasket and the rear main seal for me really slowed down, if not totally stopped my oil leak.
That said, keeping an eye on your oil levels could likely mitigate the issue for awhile.
Sent from my moto x4 using Tapatalk
BeardyHat is online now
post #38 of 48 Old 06-12-2019, 09:08 PM Thread Starter
RepBolt
Is getting the Felpro gasket make that much of a difference? Through Hughes, it's just an additional $30: http://www.hughesengines.com/Index/p...r&partid=30712
RepBolt is offline
post #39 of 48 Old 06-12-2019, 09:25 PM
PolkaPower
PolkaPower's Avatar
Felpro is excellent quality. That's what I use.
post #40 of 48 Old 06-12-2019, 11:24 PM Thread Starter
RepBolt
Just ordered the Felpro plenum kit from Hughes. Going to give that a try.
On another note, I'm on RockAuto and I'm searching through parts and wondering what exactly is the difference between "Standard Volume" and "High Volume"? For example, I'm searching for a new oil pump for my 97 JGC 5.2L and I'm not exactly sure which one I should be getting since there's multiple options under both volume types.
RepBolt is offline
post #41 of 48 Old 06-12-2019, 11:30 PM
kg6mov
Hears the voices
kg6mov's Avatar
If you don’t know why you need a high volume oil pump you want the standard one.
If you have a stock oiling system you want the standard flow pump. Melling is a pretty good brand.
kg6mov is offline
post #42 of 48 Old Yesterday, 11:45 AM Thread Starter
RepBolt
Originally Posted by kg6mov View Post
If you donít know why you need a high volume oil pump you want the standard one.
That's exactly what I was thinking lol
RepBolt is offline
post #43 of 48 Old Yesterday, 11:04 PM Thread Starter
RepBolt
Well I just ordered a bunch of new parts from Hughes and RockAuto for my ZJ. She will be healthy soon!
  • Hughes Plenum Repair Kit w/ Fel-Pro Gaskets
  • Dorman Oil Pan
  • Dorman Water Pump Stud Kit
  • Fel-Pro Oil Pan Gasket
  • Fel-Pro Valve Cover Gasket
  • Fel-Pro Water Pump Gasket
  • Gates Water Pump
  • Gates Drive Belt
  • Gates Idler Pulley
  • Gates Belt Tensioner
  • Hayden Radiator Fan Clutch
  • Melling Oil Pump
  • Strongarm Liftgate Support (R/L)
  • Strongarm Back Glass Lift (x2)
  • Wix Oil Filter
Getting these installed along with a full service. If there's anything else I should get please chime in.
RepBolt is offline
post #44 of 48 Old Yesterday, 11:20 PM
BeardyHat
BeardyHat's Avatar
  • Dorman Oil Pan
  • Gates Water Pump
  • Gates Drive Belt
  • Melling Oil Pump
  • Wix Oil Filter
Since you picked up the oil pan gasket and the oil pump, you'll be into the pan, so pick up the rear main seal and do it while you're in there.
Avoid Omix-Ada if you can, I've had several pieces from them that were straight up wrong, including a rear main.
With all the other stuff you got, you're going to be busy for awhile!
post #45 of 48 Old Yesterday, 11:26 PM
BeardyHat
BeardyHat's Avatar
Actually, might also be worth it to do all three mounts too, two motor mounts and tranny mount.
Those were another one of the early things I also tackled.
