Brake part help - JeepForum.com
 1Likes
  • 1 Post By osgruber327
post #1 of 9 Old 10-14-2019, 05:43 PM Thread Starter
osgruber327
Brake part help
Hi!
I am in need of a simple part to finish my brake rebuild. Can't seem to find it anywhere - isn't manufactured anymore and can't seem to find it anywhere.
Looking for a parking brake lever (it's the flat bar that spreads the drum pads, engaging the brake pads, when the parking brake is pulled in the passenger compartment) for a rear, passenger side, drum brake. Its for a 1993 Grand Cherokee Laredo with front disks and rear drums. The drums are "10, so the same part from an xj won't work ("9).*
Maybe someone has one not in use? Happy to pay.
Thanks
Oliver
Sent from my SM-N975U using Tapatalk
osgruber327 is offline
post #2 of 9 Old 10-14-2019, 05:47 PM
riverzj
Shoe actuator? Auto value has them Iím pretty sure
Sent from my iPhone using Tapatalk
riverzj is offline
post #3 of 9 Old 10-14-2019, 05:58 PM Thread Starter
osgruber327
It's called the parking brake strut......its the only thing thats not considered a replaceable part
post #4 of 9 Old 10-14-2019, 05:59 PM
riverzj
https://www.ebay.com/i/173710095254?...SABEgIWTvD_BwE
This?
riverzj is offline
post #5 of 9 Old 10-14-2019, 06:11 PM Thread Starter
osgruber327
Not the same.... inch 9 drum, not 10
But thank you
post #6 of 9 Old 10-14-2019, 08:24 PM
riverzj
https://www.morris4x4center.com/mopa...4713590-m.html
This claims that the xj and ZJ ones are identical. Otherwise if parts stores donít have em youíll have to go junkyard.
riverzj is offline
post #7 of 9 Old 10-15-2019, 03:28 AM
Some_Anchovies
Some_Anchovies's Avatar
The ZJ drum brakes were a rarity, so you'll have a much better time looking for XJ parts. The rear axles on those had drums much more frequently.
95' ZJ 4.0L, 5-Speed Swap, NP231, 282k
Ex-Master Mechanic-turned-Software Developer
Some_Anchovies is offline
post #8 of 9 Old 10-15-2019, 03:56 AM
K0LCB
K0LCB's Avatar
Try your local junk yard. Probably a lot of 10Ē drums around. Most drum brake parts are similar
L. C. AKA LEONARD
Itís a Jeep thing
K0LCB is offline
post #9 of 9 Old 10-19-2019, 12:46 PM Thread Starter
osgruber327
Found them brand new at Quadratec...... should have known to look there first.
riverzj likes this.
