Bleeding ABS after Master Cylinder change - JeepForum.com
post #1 of 4 Old 06-23-2021, 11:50 AM Thread Starter
Dakk
So I started to change the Master Cylinder last week. RockAuto sent the wrong part so the 93' ZJ 4.0 sat with the lines from the Master Cylinder and proportioning valve disconnected for about a week (hindsight says this was a bad move). After the new Master cylinder was bench bled and installed, I realize a bit of air probably got into the ABS. I wasn't initially concerned with air getting in the lines and such because I was going to do a flush, but I'm unfamiliar with the ABS.
I haven't bled or drove it yet, gonna do a standard bleed and see where that gets me. Any ideas what I can do with this ABS?
Dakk is offline
post #2 of 4 Old 06-23-2021, 01:13 PM
Mr. Puddles
Dealer for sure. Or you can call your local service facility (Firestone, Goodyear, NTB, ect.) and ask them to verify if their scan tool will actuate the ABS unit.
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #3 of 4 Old 06-24-2021, 06:02 AM
jeepjeepster
Most shops most likely wont be able to hook up to a 93. Before I had a MT2500 to bleed the brakes, I would raise up my Jeep and with it running in gear, apply the brakes. The ABS would go crazy. Had my vacuum bleeder hooked up while doing this.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #4 of 4 Old 06-24-2021, 09:21 AM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum.
This reply shows usage of my DRB II tool to bleed the ABS module.
My suspicion is that a normal bleed is required when servicing the brake hydraulic components, not also requiring the ABS bleed using the DRB II tool, unless somehow the ABS was activated to contaminate internal fluid during the service. I am unaware of how that contamination / activation could happen.
wingless is offline
