battery keeps draining or is it bad? - JeepForum.com
 2Likes
  • 1 Post By GOLDWING
  • 1 Post By wingless
post #1 of 4 Old 12-02-2019, 08:28 PM Thread Starter
wpatters1229
This is a battery in a 1993 jeep grand Cherokee. It sits for 3 or 4 days and the battery drains down to barely able to start. The alternator is good but for some reason, it is either being drained or can not hold a charge. I tested the drain at .369 volts when everything is off. From what I have read this is normal for this car.
My other question is how do you know if a 1 yr old battery is bad? it has been drained down to almost nothing because the jeep sat for a while why we tried to get funds to repair the engine. Will that kill the battery? It will take a charge from a battery charger but 3 or 4 days later it is run down.
How to test if there is a bad cell? I have a hydrometer.
wpatters1229 is offline
post #2 of 4 Old 12-03-2019, 10:20 PM
GOLDWING
GOLDWING's Avatar
Charge the battery and disconnect it from the ZJ. Take a voltage reading with your DVM. Check the voltage a day later and if it is lower, have the battery load tested. If the voltage stays up, youtube Eric the car guy, (parasitic drain)
GW
wingless likes this.
"The Dude Abides"
GOLDWING is offline
post #3 of 4 Old Today, 09:39 AM
Mel63
1994 ZJ
I was having the same issue with a battery that was less than a year old, checked everything for a draw, finally had the battery tested and it proved to be bad, got a new one under warranty and have not had a problem since... who would have thought lol
Mel63 is offline
post #4 of 4 Old Today, 09:58 AM
wingless
wingless's Avatar
1994 ZJ
This is correct.
When I test my battery, I first bring it to 100% state of charge, let it sit disconnected for a day, then use my carbon pile load set to discharge a good battery at the C/20 hours rate, where C is the battery Ampere-hour rating, such as 100Ah. In that example 100Ah/20h = 5A discharge load applied.
A battery with usable life will have greater than 50% capacity, or 10 hours of discharge life.
GOLDWING likes this.
wingless is offline
