battery charging issues & 50A MUX/T Tow Circuit - JeepForum.com
 2Likes
  • 1 Post By Rick1955
  • 1 Post By StPaul59
post #1 of 12 Old 03-15-2020, 03:46 PM Thread Starter
Rick1955
1997 jeep Grand Cherokee.
Symptoms: 1) Battery not at a full charge rate. 2) Current drop of 3.5A on 50A MUX/T Tow fuse circuit. Are these two related?
Here is what happens: Starts fine. Voltage indicator on dash shows 14V, immediately drops to 11.5V, then after a couple of minutes it flat lines to zero volts, then eventually pops back to 11.5V & repeats this cycle from 0 to 11.5V.
Battery: Fairly new, new post clamps. Multimeter shows 12.3V when battery is disconnected. 11.8V when cables are connected. 11.75V when engine is running.
Alternator: New. Then re-tested at Schucks & Autozone...they said it is good. Schucks said they will not replace if they test it good. Voltage drop on neg side is zero volts. Voltage drop on pos side to B+ is 1.5V
Replaced my PCM also. ouch$$$
Is my new alternator really bad or could my 50A MUX/T Tow circuit be affecting the charge? I like to figure things out myself before taking to an expert mechanic, but, perhaps it is time to take it in. Any suggestions? p.s. thank you in advance! You guys have already been a lot of help!
Rick1955 is offline
post #2 of 12 Old 03-15-2020, 03:58 PM
GOLDWING
GOLDWING's Avatar
If your "new post clamps" have the cable pinched between a piece of tin and the actual clamp, get rid of them. If you have crappy cables and dirty corroded ground points on the engine and body/chassis then take care of them. After that you may find that the new PCM was not needed.
GW
"The Dude Abides"
GOLDWING is offline
post #3 of 12 Old 03-15-2020, 04:21 PM Thread Starter
Rick1955
Thank you GW. I do have the tin clamps, will fix this. Cables & grounds are ok.
GOLDWING likes this.
Rick1955 is offline
post #4 of 12 Old 03-15-2020, 07:21 PM
StPaul59
GW
Good God I hate those clamps with a burning passion!
StPaul59 is offline
post #5 of 12 Old 03-15-2020, 07:47 PM
GOLDWING
GOLDWING's Avatar
I think that they are maybe good enough to get you home if you somehow have a problem on the trail. Beyond that, they allow lots of mechanics to earn easy money since they can cause symptoms that mimic all manner of expensive issues.
GW
"The Dude Abides"
GOLDWING is offline
post #6 of 12 Old 03-17-2020, 06:37 PM
ZblackliZard
ZblackliZard's Avatar
GW
Could you clarify this clamps story? I have some issues with my battery charging and I use clamps like this: could they be the problem?
ZblackliZard is offline
post #7 of 12 Old 03-17-2020, 06:43 PM
StPaul59
These absolutely suck. You can't ever get them to stay tight..
StPaul59 is offline
post #8 of 12 Old 03-17-2020, 06:46 PM
ZblackliZard
What should i get then?
post #9 of 12 Old 03-17-2020, 06:52 PM
GOLDWING
GOLDWING's Avatar
The ones in your pic are just a nicer version of a poor design. Crushing a stranded wire cable would not be so bad if oxygen couldn't get into the connection and cause corrosion. The cable works best with a soldered connection to a terminal lug which is bolted to a marine or military style battery terminal.
GW
"The Dude Abides"
GOLDWING is offline
post #10 of 12 Old 03-17-2020, 06:58 PM
ZblackliZard
GW
Get it now Thanks for the clarification!
post #11 of 12 Old 03-17-2020, 10:20 PM
StPaul59
I just bought new 4ga precut wires of appropriate length from the battery section (any auto store) and cut the silver lugs off and replaced them with copper lugs. You could keep what's on there but the copper is flatter and easier to work with. The lug going to the alt will most likely have to be trimmed with a dremel to fit. I just reused the starter wire and put a lug on It, it still starts fine.
StPaul59 is offline
post #12 of 12 Old 05-13-2020, 01:27 PM Thread Starter
Rick1955
1997 Jeep Grand Cherokee UPDATE: Don't Always Trust Alternator Bench Tests
1997 Jeep Grand Cherokee UPDATE: Don't Always Trust Alternator Bench Tests!
Just wanted to provide an update regarding two issues with my jeep:
1) 50A Mux/T Tow circuit
2)Alternator not charging battery
These two symptoms were unrelated. Performed voltage drop test to determine why my battery was draining overnight.The 50A fuse under the hood lead me to the F7 fuse in the cab. Finally figured my dimmer switch was the problem & replaced it........now, no battery drain!
Finally just went ahead & replaced my alternator, now the electrical system is working fine. I did take my one-yr old alternator to several shops for bench testing...they all said it was OK. I purchased it at Oreillys, but they would not exchange it based on their "good" bench test. Turns out this was a bunch of BS! In the meantime, I replaced my cables, connections, checked all grounds, fuseable links, even my PCM, just could not figure it out. Yep, it really was the alternator.
I appreciate the advice & suggestions you all have provided on the Jeep Forum. Thanks. Rick.
Rick1955 is offline
