Any ideas on tracking down a part (Key FOB)? - JeepForum.com
 13Likes
post #1 of 26 Old 01-09-2019, 02:28 PM Thread Starter
klaxmaster
klaxmaster's Avatar
I found out somewhat recently that the 93 ZJ actually had a Key-less entry remote FOB. I bought my Jeep early last year, and i only received one key, and never thought much about it. I never even considered that it could have a FOB since its a 1993.
So I have been trying to track down and purchase a FOB, but all i can seem to find is the empty case for the 93-96 ZJ (no transmitter inside). Does anyone have any suggestions or previous experience in purchasing this model FOB. Or know if any other FOB (from other years) is compatible?
I really want one, because unlocking the driver door with the key no longer disables the alarm. So i have to use the lift gate to disable the alarm, then unlock the driver (kind of annoying.) If the lift gate fails, i wont have a way to disable it, except for permanently by shorting out that Violet/Yellow wire in the door bundle to ground. I don't really want to do that, since i don't live in the best neighborhood, and it is more than an alarm, but is actually a fuel pump kill switch, and i like the idea of having just a little bit of deterrent on my baby.
Let me know! I'm going to go to a Jeep dealership today and see if they can still get them...
If it ain't broke, fix it with a larger part.
klaxmaster is offline
post #2 of 26 Old 01-09-2019, 02:50 PM
kg6mov
Hears the voices
kg6mov's Avatar
You can usually find them on ebay, or sometimes junkyards. For a 93 it’s the IR type that can be programmed at home, so at least you’re good there.
The range isn’t fantastic on the IR system, some people have swapped for a differen chrysler RF system.
klaxmaster likes this.
kg6mov is online now
post #3 of 26 Old 01-09-2019, 03:32 PM Thread Starter
klaxmaster
klaxmaster's Avatar
Originally Posted by kg6mov View Post
You can usually find them on ebay, or sometimes junkyards. For a 93 itís the IR type that can be programmed at home, so at least youíre good there.
The range isnít fantastic on the IR system, some people have swapped for a differen chrysler RF system.
I've definitely looked on ebay, no luck currently. thanks though.
I dont think i've ever seen a set of keys at a junkyard, but anything is possible i guess!
post #4 of 26 Old 01-09-2019, 03:51 PM
1shotleft
1shotleft's Avatar
You won't find keys but they do collect key fobs, as far as the driver side door there should be a sensor attached to the back side of the lock in the door.
Sent from low orbit using Tapatalk
1shotleft is offline
post #5 of 26 Old 01-09-2019, 04:39 PM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum.
This topic shows the programming for the 56009031 IR remote key fob.
The OEM part runs about $200, when it can be found.
The link has one of the aftermarket fobs, that I understand also work fine.
This topic shows the IR key fob repair to swap the internal switches.
wingless is offline
post #6 of 26 Old 01-09-2019, 05:18 PM
Xpress
Xpress's Avatar
It will be a 2 button fob, they pop up on eBay all the time. The 3 button is the IR style and only works for 96-98 models. As mentioned, you can program the IR remote yourself but the range is limited to ~5ft.
The switch on the door cylinder is called a 'Door Alarm Disarm Switch' and can be sourced from a number of places.
'96 ZJ 5.2L, IRO 3.5" lift, KOR radiator support, MVF steering brace, IronMan 1 Ton
Xpress is offline
post #7 of 26 Old 01-09-2019, 11:48 PM
Kolak
Vendor
Kolak's Avatar
I have a basically brand new fob from my old 1993. It was the spare one and I don't think it was ever used. The Jeep is long gone but I still have the fob
PM me or email me at [email protected] if you still need one.
wingless and klaxmaster like this.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #8 of 26 Old 01-10-2019, 05:20 AM
DirectMatrix
I bought this one to eventually convert to a radio frequency system. You get better range and the remotes are way cheaper and more plentiful.
https://www.ebay.com/itm/93-94-95-Ch...item2c70afef64
92 YJ, Delilah
DirectMatrix is offline
post #9 of 26 Old 01-10-2019, 06:21 AM
jeepjeepster
I highly recommend converting to the RF system that was used in Chrysler vehicles of that era. Im not sure what vehicles used it but I know concordes and 300's did. At first I gathered up all of the IR remotes that I could find then decided they were 98% useless. Wired mine up so it unlocks the drivers door on the first press then all of them on the second. The range isn't great, maybe 10' max if you're holding the remote up. Works in your pocket if you near the jeep though, which is handy.
https://www.jeepforum.com/forum/f13/...ersion-676076/
If youre interested in fixing the alarm issue, mine was as simple as epoxying the little switch back onto the back of the key cylinder inside of the door. It typically snaps on but it wouldn't stay on anymore. Sometimes they do just go bad though.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #10 of 26 Old 01-10-2019, 07:25 AM
zjosh93
...it is more than an alarm, but is actually a fuel pump kill switch, and i like the idea of having just a little bit of deterrent on my baby.
Are you sure about that? I definitely have driven my 93 around the driveway with the lights flashing and the horn honking.
I fixed my IR remotes but they really only worked when they were touching the glass and pointing toward the eye. All my door lock actuators failed so it the remote doesn't lock or unlock the doors either. It's basically a useless system.
zjosh93 is offline
post #11 of 26 Old 01-10-2019, 07:30 AM
zjosh93
Do you have a link? I looked a while back and all I found were a couple NOS parts on ebay and they were around $80. The stock ones on my 93 front doors disintegrated and all the junkyard ones I've found were the same. It's just a simple switch though and I had plans to fabricate a bracket to hold a momentary contact switch in there somewhere but I just got used to not having the alarm.
zjosh93 is offline
post #12 of 26 Old 01-11-2019, 08:01 AM
Xpress
Xpress's Avatar
It appears they have all dried up. When I looked a number of weeks ago I was able to find them. Might be a dealer only part now.
Xpress is offline
post #13 of 26 Old 01-12-2019, 07:28 PM
blkdrgn42
1994 ZJ
Considering how cheap zj's are, I have often thought about buying one that has a key fob, programming it to my vehicle, and reselling the donor. If you are a shrewd negotiator, you might not be out that much money after it's all said and done. Bonus if the donor has other parts for your vehicle that are kind of worn on yours but still functional. Swap straight across. I mean an $800 Jeep with a fob and $200 worth of usable parts you need that gets resold for $700 is a win in my book.
blkdrgn42 is offline
post #14 of 26 Old 01-12-2019, 07:46 PM
wkbear
wkbear's Avatar
There's a site called keylessride.com I had looked at in the past, but decided to just use my key. They had the correct fob and you could look at the page. Now it requires you to make an account for some reason. Still might be worth looking at.
1995 Grand Cherokee Ltd., 5.2, 249, stock (for now)
wkbear is offline
post #15 of 26 Old 01-12-2019, 07:46 PM
downs
downs's Avatar
1995 XJ Cherokee
I scooped one up on EBay for my XJ (they use the same IR remotes as the ZJs of that era) for 40 dollars about 2 months ago. Programmed in a few minutes in my driveway. I saw them as recently as 2 weeks ago on Ebay going for 60 to 80 dollars. Works fine for me but you have to accept the IR system has limited range.
Here's 3 I foudn on Ebay just now. Not cheap looks like prices are driving up but for me having these little things working on the old Jeep is worth a little extra cost.
https://www.ebay.com/itm/Oem-Jeep-Ch...dXz:rk:28:pf:0
https://www.ebay.com/itm/NEW-1993-19...!-1:rk:35:pf:0
https://www.ebay.com/itm/Keyless-Rem...Vf:rk:171:pf:0
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is offline
