Annoying Clunk after Stopping - JeepForum.com
post #1 of 14 Old 08-08-2021, 12:20 PM Thread Starter
JonS
I have been getting this annoying clunk after stopping at a red light or stop sign. I think it’s the transmission but it could be the transfer case. Any idea what it might be?
JonS is offline
post #2 of 14 Old 08-08-2021, 12:28 PM
MaintMech
MaintMech's Avatar
Do you get the clunk on acceleration after stopping or after a complete stop?
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #3 of 14 Old 08-08-2021, 12:31 PM
Tinker0000
Could be a bad mount allowing the engine, trans to move.
1984 Jeep CJ7 258 Spring Special edition.
Tinker0000 is offline
post #4 of 14 Old 08-08-2021, 05:12 PM Thread Starter
JonS
Sometimes upon accelerating but mostly up on stopping. I put my foot on the brake and accelerator in drive and in reverse and did not see the engine move implying the motor mounts are OK.
JonS is offline
post #5 of 14 Old 08-08-2021, 08:22 PM
Rapidrob
Rapidrob's Avatar
The proper method is to jack up both rear wheels and put the Jeep in drive. Spin the wheels to 20-30 mph indicated and stamp on the brakes. Have yourself or a friend look at the engine mounts or transmission mount while doing this.
If the mount/s are bad you will see and hear them.
'Nam Vet
Tin Can Sailor
President
NM MILSURPS
Rapidrob is offline
post #6 of 14 Old 08-08-2021, 08:50 PM
PolkaPower
PolkaPower's Avatar
Originally Posted by JonS View Post
I have been getting this annoying clunk after stopping at a red light or stop sign. I think itís the transmission but it could be the transfer case. Any idea what it might be?
Check the rear upper track bar bolt for tightness. I've had one loosen up a few years ago and on starts and stops it would slide forward or backwards and clunk. Since its a unibody the sound travels all around and can seem like it's coming from another area. Took a few days to figure it out.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #7 of 14 Old 08-08-2021, 08:59 PM
gutthans
gutthans's Avatar
Let's go front to back:
Torque of acceleration or deceleration in gear can wiggle the block with bad motor mounts
Backlash (wear) can be heard as a clunk from any gear surface that is in the drivetrain
Failing U-joints/straps make a clunk
Rocking transmission can clunk if a mount is bad or the torque arm is loose
Chain slack in the tcase can clunk (but you'd have to be in 4 wheel) (I think)
Shifting axlehousings clunk, but also have a torque twist that throws the vehicle slightly
Rear track bar already mentioned
Loose exhaust hangers can cause the pipe/muffler to whack the underbody
That's it for me.
gutthans is offline
post #8 of 14 Old 08-09-2021, 05:50 AM
HighLonesome
HighLonesome's Avatar
I had this happen and it was control arm bushings.
HighLonesome is offline
post #9 of 14 Old 08-09-2021, 09:15 AM Thread Starter
JonS
Thanks everyone- will check all of the above.
JonS is offline
post #10 of 14 Old 08-10-2021, 06:21 PM
T Hoff
T Hoff's Avatar
1975 CJ5
Few things come to mind.
Drive shaft U joints
Brake caliper pin loose or one missing.
Motor or trani mounts.
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
T Hoff is offline
post #11 of 14 Old 08-10-2021, 06:38 PM
catfish51
Lock the brakes and rev the motor in forward Then lock the brakes and rev the moor in reverse have someone watch the motor and then the transmission and transfer case to see if they jump in either direction That will tell if the mounts are bad Then on the ground and in park try and rotate the drive shafts back and forth to see if there is any movement of the u joints .This will also show the gear slop in the differentials Check the caliper mounting bolts to see if they are loose You can also have someone with the motor running turn all the way right and then all the way left and see if the tracking bar is moving at it's 2 mounts
catfish51 is offline
post #12 of 14 Old 08-10-2021, 09:44 PM
buster51
driveline clunk
Our 97 Cherokee has done it since new. On ours it's the slip joint on rear driveshaft. As long as I keep it greased it's OK, but I have had to take it apart and clean or it sticks and clunks
buster51 is offline
post #13 of 14 Old 08-11-2021, 05:48 AM
TaperedRoller
I second the rear driveshaft theory. Remove rear driveshaft, clean the slip yoke with brake cleaner (transfer case end) to remove old grease, and liberally relube using silver or gray antisieze.
TaperedRoller is offline
post #14 of 14 Old 08-11-2021, 03:15 PM
jb1331
When is the last time your changed / checked your diff fluids? I had an issue like that years ago and it went away after changing the fluid.
1997 ZJ Laredo 4x2 I6 Bought 2/1999 @29k, 186k
2004 Jeep Liberty LTD. Totaled @ 177k
jb1331 is offline
