AC Compressor has mind of its own? - JeepForum.com
 2Likes
  • 2 Post By V8GCZJ
post #1 of 6 Old 11-14-2019, 05:02 PM Thread Starter
wn2091kc
1994 ZJ
On my 94 ZJ, I noticed today that the ac compressor is cycling on/off occasionally as it would normally do in hot weather with the A/C turned on. The only problem is is that it is 40F outside and the a/c switch is OFF.
I pulled the LP switch plug off the drier and it stopped cycling. I also pressed the A/C switch on the dash a few times on/off to make sure it wasn't sticking (which I don't think it is). A/C worked fine this past summer but haven't used it since early August.
Maybe I'm having a senior moment here but I don't think this should be happening with the a/c switch off... Even if it was low on refrigerant, without the A/C switch turned on, I would not expect the compressor to run. Is my thinking correct here?
94 ZJ Laredo 5.2 Magnum
wn2091kc is offline
post #2 of 6 Old 11-14-2019, 05:11 PM
V8GCZJ
Are you sure it wasn't on defrost? The AC will cycle there also.
GOLDWING and Benthal8 like this.
V8GCZJ is offline
post #3 of 6 Old 11-14-2019, 05:23 PM Thread Starter
wn2091kc
1994 ZJ
Really?
As a matter of fact, I generally keep it on defrost/floor setting as was the case here...I honestly never noticed the compressor cycling on before but now that I think of it, that makes sense.
Thanks!
wn2091kc is offline
post #4 of 6 Old 11-15-2019, 01:45 AM
Zilliver
On all Chrysler stuff - the A/C is turned ON if you use defrost. Regardless of the A/C button.
If its too cold outside, the A/C will stay off.
98 Grand Cherokee 5.9 - daily
95 Grand Cherokee 5.2 - offroad
Zilliver is offline
post #5 of 6 Old 11-15-2019, 10:55 AM
mikem350
1994 ZJ
Not just Chrysler...most cars
Proud owner of two DD 4.0 ZJs
Flame Red 94 mint!
Silver 98 just hit 320k miles....runs great!
mikem350 is offline
post #6 of 6 Old 11-15-2019, 03:16 PM Thread Starter
wn2091kc
1994 ZJ
That the a/c runs when on the defrost setting was my learning for the day!
wn2091kc is offline
