98 ZJ No audio from aftermarket headunit - JeepForum.com
post #1 of 5 Old 09-27-2012, 10:57 AM Thread Starter
aerick79
Hi, everyone, I have a 98 ZJ laredo,with no audio. I do get audio from the sub but that's about it. I did tons of searches. So now its time to ask for help. I have a Alpine Headunit, cde 1333bt, with NO infinity amp, and 2 12in Polk DB, and a 1000 powertube amp.
I tired all the general info. Like checking the # 1 and #7 fuse but 20amp that's fine. All wiring has no issues, No shorts
I don't want to re-wire my truck, but is there anything I have missed?
Thanks again
aerick79 is offline
post #2 of 5 Old 09-27-2012, 02:38 PM
SKorch630
Sure you have the speakers wired properly? Obviously you're getting power/sound to/from the sub, so there's no issue there. Ruling out possibilities, I'm left with wiring to the speakers. Pull the headunit, and rewire those leads. That's about all you can do.
SKorch630 is offline
post #3 of 5 Old 09-27-2012, 02:54 PM Thread Starter
aerick79
Thanks for the advice.
aerick79 is offline
post #4 of 5 Old 09-27-2012, 04:31 PM
timmay5309
timmay5309's Avatar
http://www.the12volt.com/installbay/...tail/1226.html
Here is a link to the color codes on all of the wiring for the stereo. Not trying to disrespect, but did you check to see if the mute was on?
timmay5309 is offline
post #5 of 5 Old 09-27-2012, 04:48 PM
somebody5788
somebody5788's Avatar
1994 ZJ
I'm going to bet that it works in FM mode and not in CD or any other media mode. On mine the factory amp wire is also the antenna wire for some reason. I had to use my radio's amp turn on wire for the antenna and factor amp and sub amp.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
Aftermarket audio for grand cherokee limited with infinity Sk3rR-JGCL WK Grand Cherokee & XK Commander Forum 3 09-05-2012 10:10 PM
98 ZJ Aftermarket Audio draining alternator jthayer0715 ZJ Grand Cherokee Forum 48 03-12-2012 08:24 AM
Cleaning up an aftermarket audio mess... loudog3114 ZJ Grand Cherokee Forum 8 01-20-2011 03:07 PM
Aftermarket Stereo Headunit Double DIN snapplecapz WK Grand Cherokee & XK Commander Forum 1 09-18-2010 01:52 PM
Steering wheel controls with aftermarket headunit!!!!! jim2527 ZJ Grand Cherokee Forum 0 11-04-2005 06:06 PM
