98 ZJ Humming Noise From Front. Please Help! - JeepForum.com
post #1 of 21 Old 06-20-2016, 10:56 PM Thread Starter
JaredD33
I've been battling a humming noise from the front end of my 98 5.2 ZJ for quite some time. I had an axle seal blow and the shop told me the humming noise I heard was probably due to low fluid in the differential. After a costly repair bill, I decided to do it myself. I finally got around to it, and I replaced both inner axle seals in the differential. So far, no leaks, and I thought the problem would be fixed. But the humming/whining noise is still there. The noise is not noticeable from 0-15 mph. But it's the worst from about 15-40, then smooths out into a dull whining noise from 40mph+. When it's between 15-40 it's a very loud, noticeable humming/whining from the front end and I can feel it everywhere (seat, steering, brake, gas, etc). My front end is very misaligned due to a recent ditch I ended up in, but it wasn't a problem until a few days after when my seal blew. So I'm unsure if that's the culprit or not. I don't think it's the bearing because I feel it throughout the whole front. Please help me figure this one out, cuz it's puzzling the hell out of me.
JaredD33 is offline
post #2 of 21 Old 06-23-2016, 12:42 AM
Candymancan
a bad wheel bearing can vibrate the whole vehicle.. just saying. I had one in my wagoneer and the vehicle vibrated in the floorboards and would make wummm wumm wummm wumm noises
Candymancan is offline
post #3 of 21 Old 06-23-2016, 02:02 AM
PolkaPower
PolkaPower's Avatar
I would fix your front end lol. Remove the front drive shaft and see if the noise goes away. That will help narrow it down. You can't really tell **** with your messed up front end though.
You are trying to solve for one problem when you have a bunch of other problems. Doesn't make sense. Fix the stuff you know is wrong first.
PolkaPower is offline
post #4 of 21 Old 06-24-2016, 02:52 PM Thread Starter
JaredD33
So I went to the shop, got my alignment. On my way home, no change. Steering is jacked. Noise is the same. It's like driving on ice. The wheels go where they want. When it shifts, it sometimes jerks one way or another. AND on top of it all, my seal blew again. Any ideas on what's wrong or how to fix it? I'm thinking something is wrkng inside the differential. But I don't know if it'd be as simple as changing the gears and seal and it be fixed. I'm really at a loss here.
JaredD33 is offline
post #5 of 21 Old 06-24-2016, 03:10 PM
DaNgER13
DaNgER13's Avatar
Pinion bearing. Is it louder on Decel? When you let off the gas it howls. Or when going through an intersection with a high crown it changes pitch but is still there when the suspension travels.
Sounds like you have other things to worry about though. Don't bother pulling the front shaft, the only thing that does is fry your VC and makes the noise less noticeable.
I would fix that steering first. I've beendriving with a bad pinion bearing for almost a year now
A baby seal walks into a club...
DaNgER13 is offline
post #6 of 21 Old 06-24-2016, 03:15 PM
PolkaPower
PolkaPower's Avatar
It's a 98 so no it does not hurt the VC. Only 93-95 does that matter. Basic information.
post #7 of 21 Old 06-24-2016, 03:28 PM
DaNgER13
DaNgER13's Avatar
I caught myself after I posted.
You Win. You get a free cookie
DaNgER13 is offline
post #8 of 21 Old 06-24-2016, 03:30 PM
DaNgER13
DaNgER13's Avatar
Duplicate
DaNgER13 is offline
post #9 of 21 Old 06-24-2016, 08:04 PM Thread Starter
JaredD33
I'll try pulling the front shaft. I think it's dumb as hell how its 4 wheel all the time anyways. Do you think my steering issue is something totally unrelated? The front end alignment didn't help anything at all.
JaredD33 is offline
post #10 of 21 Old 06-24-2016, 08:43 PM
MrRoundel
I agree with the idea of fixing the steering issue first. That stuff can kill you, and perhaps others. If it feels like you're driving on ice when you're not driving on ice, that's a problem. Conversely, in most worst case scenarios, the differential noise should only leave you stranded and in need of a tow. Good luck.
MrRoundel is offline
post #11 of 21 Old 06-25-2016, 10:39 AM
Uniblurb
Uniblurb's Avatar
^ agree with MrR and you have 2 separate problems while you best get your steering fixed first!
That must have been a "fly-by-night" or "speedy" alignment shop to do an alignment when you have some bent or broken steering related parts. Most good ones even help diagnose the problems while saying bring it back for an alignment after you get those problems fixed or give you an estimate on them doing the repairs.
It's probably best to have a helper turn the steering wheel back/forth while you're under the front looking for loose, sloppy, or broken parts. Who knows what's bad under there after running it into a ditch.
Your differential is a whole different ball-game while some real good info by Kg in that link for setting up a differential right.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #12 of 21 Old 06-26-2016, 03:04 PM
98318242
How hard did you hit the ditch? I wonder if you possiblye bent or tweaked the front diff.
Sent from my VS980 4G using Tapatalk
98318242 is offline
post #13 of 21 Old 06-26-2016, 10:45 PM Thread Starter
JaredD33
I hit pretty hard. Probably going at least 25-30 MPH. My right front wheel took the hit. The steering was jacked after that. The differential problem happened a few days later.
JaredD33 is offline
post #14 of 21 Old 06-27-2016, 06:36 AM
LowBudgetZJ
Yeah you probably bent something, maybe even an axle tube.
FYI, it's not always in 4wd unless your viscous coupler is toast. When you lose traction 4wd kicks in with a properly functioning viscous coupler.
98 ZJ 4.0 42RE NP242
75 CJ5 232 T14 D20.....STOLEN
LowBudgetZJ is offline
post #15 of 21 Old 06-27-2016, 10:03 AM
Uniblurb
Uniblurb's Avatar
It's still beyond me how a "so called shop" could even align it with bent or broken parts?? Did you ask them to inspect if for damage and mention running into a ditch at 25-30mph?
Uniblurb is offline
bearings , differential , transfer case
