98 zj 4.0 high flow catalytic converter - Page 2 - JeepForum.com
post #16 of 21 Old 02-14-2020, 04:00 PM Thread Starter
Gregory98zj
SORRY that was supposed to be 1tbs per quart of zinc.so 7 tbs total.
Gregory98zj is offline
post #17 of 21 Old 02-14-2020, 04:03 PM Thread Starter
Gregory98zj
MR PUDDLES. I'm 100%sure theirs something in the pipes.just a big constriction in the cat.my pipes are about 7 months old.the cat wasnt rattling or getting hot then so I only replaced the pipes and muffler.
post #18 of 21 Old 02-14-2020, 04:05 PM
Mr. Puddles
Originally Posted by Gregory98zj View Post
no it will only pull codes.im was getting around 19 to 20 mpg.now about 15.
I only use 1 tbs of Lucas engine break in oil addative which is zinc or zddp.
The drop in mpgs could be due to the cat having issues. Id say spend the cash and get it swapped and we can address and additional issues then. Until then we are doing with skewd data
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #19 of 21 Old 02-14-2020, 06:12 PM
zjosh93
That works out to about 780 ppm extra ZDDP. Double check that your oil doesn't have more than 1,200 or so already (unlikely) or the ZDDP can start to attack grain boundaries in the cast iron.
A bit off topic I know.
I don't think the ZDDP is the overheating issue though. Zinc and phosphate poison the cat so it stops reacting. It just stops working.
zjosh93 is offline
post #20 of 21 Old 02-15-2020, 09:37 AM Thread Starter
Gregory98zj
so just how much do I need to use for 7 quarts of oil.im currently using 7 tbs.so in tbs measures how much would be correct.
post #21 of 21 Old 02-16-2020, 04:08 PM
zjosh93
Depends on the oil you're using. I use Shell Rotella T4 15W40. It has 1200 ppm ZDDP already. That'd be real close to the limit. I'd use less ZDDP additive with that oil. (Or none at all as I actually do)
If you are using any of the gasoline engine modern oils they probably have less than 800 ppm ZDDP so you'd be fine with your 1 tbsp.
zjosh93 is offline
