'98 ZJ 4.0 Cranks but will not start - Lots of parts replaced - Please Help! - Page 2 - JeepForum.com
post #16 of 27 Old 01-07-2017, 12:50 PM Thread Starter
TheGrimJeeper
Originally Posted by ZeeJay1997 View Post
it takes two minutes to swap a relay.
Sorry, forgot to mention I did that. There was no difference. I tried swapping it with the horn, the a/c and the wiper relays.
TheGrimJeeper is offline
post #17 of 27 Old 01-07-2017, 12:56 PM
ZeeJay1997
Originally Posted by ihbinder View Post
I installed the new NTK 02 sensors. The "older" relays worked for the short time that I ran the engine where they did not work at all when the Bosch 02 sensors were in place.
This tells me that the relay has weak contacts. did you try swapping it with another relay as well?
ZeeJay1997 is offline
post #18 of 27 Old 01-07-2017, 01:27 PM Thread Starter
TheGrimJeeper
Video of the problem
Alright, I'm not sure if JF allows for embedded videos but here is the Youtube link of what happens with a full battery charge:
https://youtu.be/bfm4jGRcQPQ
I just shot that maybe 20 minutes ago and the weather was decent enough to where it shouldn't affect anything.
post #19 of 27 Old 01-07-2017, 02:32 PM
ZeeJay1997
You've got a lot of variables working against you. As you said, cold weather is not your friend.
It difficult to tell from the video, but here's my theory...
When it fired, it back fired and smoke came out in the engine bay. maybe a sign of a plugged cat. the symptoms you described in your first post are indicative of this condition. But the bad fuel pump would also cause those symptoms.
If it is totally plugged, it cannot create enough vacuum in the intake to fire. The back pressure from the exhaust goes around the valve seats and pressurizes the intake causing the fuel to be pushed around a failing injector oring.
You have a couple of options to explore this theory. You can pull the O2 sensors and try it. The nuclear option is to drill some holes in front of the cat. I dont recommend this unless you can weld.
You really need a compression tester, a vacuum gauge, and a fuel pressure tester right now.
And dont discount the earlier suggestion that the fuel lines may have ice in them. Maybe try some HEET.
post #20 of 27 Old 01-08-2017, 05:20 PM Thread Starter
TheGrimJeeper
Well, thank you so much. I appreciate your suggestions a LOT. It's really hard to get anyone to come over to physically LOOK at the car because winters are so crumby here,
Since I consider myself a novice mechanic still....I don't own any of those tools, and I can't weld very well. But I know a few people who do so I will start making some phone calls tomorrow. In the meantime I may try some HEET, but it should be getting significantly warmer in the next couple days.
If the cat is the issue...that was a concern of mine from the beginning but I sort of forgot about it since the thought of it makes my wallet very sad. But after some research I realized I could do this myself and I know a few people that would either be willing to let me borrow a welder or possibly come weld it for me for a small fee. Before I decide to weld it, I may try your hole-drilling suggestion just because it interests me.
If anyone else has any suggestions, feel free to let me know but ZeeJay1997 has brought up some points that address my initial concern, so I will definitely follow their suggestion for now...I'll let you know how the pressure, vacuum and compression testing goes.
post #21 of 27 Old 01-08-2017, 08:16 PM
Uniblurb
Uniblurb's Avatar
Many parts stores, like Advance & Autozone, have loaner tools like Zee mentioned. Not sure about the Chicago area but they do here. Normally you pay full price, can keep for up to 30 days, then return for a full refund. All 3 of those tools together are probably $100 online but a parts store may charge more.
Good suggestion by Zee in dumping a bottle of "HEET" in the fuel tank. Even if you have ice forming in the line/filter now it will help dissipate the water once it warms up in outside temps. May also melt the ice itself in the lines.
While a little pricey the catalytic converter for your 98 4.0 may be cheaper than you think. While a little louder than OE the Walker 15820 cat is $110 on Rockauto or $117 on Amazon with prime.
http://www.rockauto.com/en/moreinfo....sn=374&jsn=374
RA probably charges $10 for shipping but you can cover part of that cost by entering in discount code 5387936748131651 in the "How did you hear about us?" box at checkout for 5% off.
It's kind of tricky getting the cat out of the middle of the front pipe and muffler, especially with no power tools/grinder. I've done it before with lots of heat from a propane torch but you don't want to destroy/dent the muffler inlet or front pipe outlet. I've used a hacksaw and chisel/hammer but lots of heat and rust cutter. Then you could just clamp in the cat w/o having to use a welder.
It would be much better to do some testing first. At least when it's just cranking over doing nothing shut it off. Then remove the cap on the drivers side fuel rail and push in on the shrader (air type) valve pin with a small screwdriver with a rag over it to see if fuel pressure comes out. Best to wear safety glasses and good luck.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #22 of 27 Old 01-10-2017, 08:22 PM Thread Starter
TheGrimJeeper
I tried this....It got up to almost 40 degrees today so I figured it would be a good day. No start still...although it does try a lot hard TO start.
This is actually a really good idea, thank you. I will do this at LEAST until I can get to my welder, even.
I have someone bringing a guage over this weekend but I have pressed on the fuel pressure valve with a screwdriver and it HAS pressure when primed...Fuel sprays out pretty far, for about a half-second.
post #23 of 27 Old 01-10-2017, 10:23 PM
trol1374
Sounds like what my 95 limited did. First the starts were difficult. Then sluggish. Changed fuel filter, helped some. Changed TPS, IAC, still no. Then it was harder and harder to start of that first start when it got cold. I changed the PCM and all the problems went away. So did you check your ECM? Or try finding one at junk yard.
trol1374 is offline
post #24 of 27 Old 01-10-2017, 11:43 PM
ZJ35
i replaced the capacitors in the PCM and mine started right up… not sure if this was discussed already.
ZJ35 is offline
post #25 of 27 Old 01-15-2017, 02:56 PM Thread Starter
TheGrimJeeper
It's allliiiivvveeeee!!!
Holy hell....Today was nice so I decided to take my o2 sensors out and try and start it.
The front sensor came off very easily with an adjustable wrench and the rear sensor needed a little Blaster fluid (similar to WD-40) but wasn't too big of an issue.
It started right up! It's just very loud and I don't have much room to move, but it seemed as if none of my gears were working, which is odd. I've never had a problem with my transmission. So I'll have to go back and check everything...check my relays and such...But I am BEYOND excited right now...
I want to thank everyone for easing my Jeep stress...
Next step: New Cat....I have a friend who will weld one on for me...I just have to buy it.
I will update with any new developments.
post #26 of 27 Old 01-15-2017, 03:00 PM Thread Starter
TheGrimJeeper
Would a diagnostics computer tell me if the ECM is bad? I'm asking for future reference because I've tested it with two different units and haven't gotten codes for that.
post #27 of 27 Old 01-15-2017, 05:51 PM
ZeeJay1997
When you disconnect the battery the cat monitor goes to not ready state and will not turn on the CEL. And it will not set a cat code unless it's been through the drive cycle that sets the monitor to ready.
And you may need to replace those O2 sensors since you didn't get a code when it was running.
About the transmission, be sure the connector on the top on the transmission is seated good and swap the transmission relay with a known good relay.
cps , fuel pump , iac , tps
