´98 V8 crank sensor plug original location - Page 2 - JeepForum.com
 2Likes
post #16 of 28 Old 02-28-2020, 12:25 PM
tjx0116
Originally Posted by Timo_90xj View Post
Looking from behind the engine, it sits at around 1 or 2 o' clock. Two bolts on the top, they are either 1/2" or 13mm. Unfortunately I don't have a picture of the exact location, but it's the only sensor in that area.
I can do it from above or below with my modified exhaust, but IIRC with the stock setup it's a pretty damn tight fit either way.
Thanks, Timo! Is this the CPS in the photo?
tjx0116 is offline
post #17 of 28 Old 02-28-2020, 12:35 PM
wingless
wingless's Avatar
1994 ZJ
Here is the CPS, visible after lowering the transmission (removing the transfer case linkage and disconnecting the exhaust support).
Mine was retained by Allen head cap screws w/ loose internal tooth lock washers.
wingless is offline
post #18 of 28 Old 02-28-2020, 12:37 PM
wingless
wingless's Avatar
1994 ZJ
No, that looks like the oil pressure sensor.
wingless is offline
post #19 of 28 Old 02-28-2020, 12:39 PM
tjx0116
Is this a 5.9L in the shot?
tjx0116 is offline
post #20 of 28 Old 02-28-2020, 12:56 PM
Timo_90xj
Timo_90xj's Avatar
I agree, that is definitely the oil pressure sensor.
Wingless has a 5.2, but 5.9 is exactly the same. CPS mounting bolts on my 5.9 are a combination of a hex-head with (IIRC) #3 Phillips- head slot on top.
***Under construction***
Timo_90xj is offline
post #21 of 28 Old 02-28-2020, 01:07 PM
tjx0116
I still can't find it. Perhaps I'm overlooking it. Here are a couple of shots of my passenger side engine bay. Am I at least starting in the correct location?
tjx0116 is offline
post #22 of 28 Old 02-28-2020, 01:23 PM
wingless
wingless's Avatar
1994 ZJ
Not seen or felt from the top.
My image from below shows the part, retained by the shiny bracket, below the wingless watermark.
Note oil pressure sensor, then distributor is to left of wingless watermark.
wingless is offline
post #23 of 28 Old 02-28-2020, 02:47 PM
Timo_90xj
Timo_90xj's Avatar
You should be able to spot it with a flashlight if you peek through between the transmission/ engine and passenger downpipe or thereabouts.
Like I wrote and as can be seen in Wingless' photo, sensor is located at about 1-2 o'clock if you look from behind the engine. It really cannot be seen from above - and not that well from below either - but can be somewhat accessed if you know where the sensor is.
post #24 of 28 Old 02-28-2020, 07:21 PM
tjx0116
Thanks, guy! I really do appreciate your efforts to help me locate this sensor. I'll have another go at it when the weather warms up in a few days.
tjx0116 is offline
post #25 of 28 Old 03-01-2020, 01:56 AM Thread Starter
Zilliver
Were you able to replace the CPS from the engine bay or underneath? Do you have any shots of the CPS attached? I'm having a hard time finding it. Thanks!
The connector from underneath the car. The sensor from the engine bay.
The connector in my ´98 (V8) is near the O2 sensor underneath.
On my´95 (V8) the connector was on top, near the oil sensor.
98 Grand Cherokee 5.9 - daily
95 Grand Cherokee 5.2 - offroad
Zilliver is offline
post #26 of 28 Old 03-02-2020, 03:25 PM
tjx0116
The crankshaft position sensor has been replaced! As expected, my hands and forearms are scratched up, but I've shed not a drop of blood.
Thank you all for your help with this! I look forward to not stalling on a road without a shoulder.
tjx0116 is offline
post #27 of 28 Old 03-29-2020, 10:43 AM
Hempinfool
Hempinfool's Avatar
I know this is a little off topic but what is the connector that comes off the harness with the crank sensor?
When I replaced my crank sensor I noticed that there was a single wire connector that was not connected.
For reference, It was behind the distributer like normal.
Hempinfool is offline
post #28 of 28 Old 03-30-2020, 01:04 AM Thread Starter
Zilliver
The single wire is probably oil pressure sensor for 93-95 ZJ
Zilliver is offline
