'98 GC w/5.2 Front Differential Noise - JeepForum.com
post #1 of 5 Old 01-20-2015, 10:48 PM Thread Starter
sldghmr300
New to me Laredo has grinding noise in the front differential. Had mechanic change fluid and found metal shavings on plug and black burned smelling oil/grease. Installed new fluid - no change. Where do I get a new or used differential if that is the solution (I'm no mechanic so rebuild is not for me) and what will likely be needed besides the differential (also where do I locate the exact part number for it?) - axles, etc?
Thanks
sldghmr300 is offline
post #2 of 5 Old 01-28-2015, 11:17 AM
TJorange
You could pull the whole Axle assembly from a junk yard. Pretty straight forward. Its just really big and heavy.
TJorange is offline
post #3 of 5 Old 01-28-2015, 11:34 AM
PolkaPower
PolkaPower's Avatar
You will spend more piecing it together or rebuilding it than grabbing a whole axle from the yard.
PolkaPower is offline
post #4 of 5 Old 01-29-2015, 01:42 PM Thread Starter
sldghmr300
Thanks! Is it better to use entire axle or just the differential?
post #5 of 5 Old 01-29-2015, 02:15 PM
PolkaPower
PolkaPower's Avatar
I would just grab the entire thing.
front differential , parts identification , replacement
