97 seat belt adjuster knob - JeepForum.com
post #1 of 6 Old 02-15-2019, 04:50 PM Thread Starter
wilet-moeracing
1979 FSJ Cherokee
Help, how do you remove the knobs from the seat belt height adjuster slides on the b, c pillars so I can install the headliner back in? I removed the covers already and broke a rear slider knob of the bracket and would like to get this done, I have spent 2 plus hours on the internet and have found the questions asked but no answers, Thanks, Tim
wilet-moeracing is offline
post #2 of 6 Old 02-16-2019, 12:33 AM
SAR-Swimmer
Should just pull off, that's the way I've gotten them off in past.
SAR-Swimmer is offline
post #3 of 6 Old 02-16-2019, 03:55 AM Thread Starter
wilet-moeracing
1979 FSJ Cherokee
I tried that on the rear and it broke off. I will check again tomorrow and try the other side.
post #4 of 6 Old 02-16-2019, 12:38 PM
Timo_90xj
Timo_90xj's Avatar
Use a flathead screw driver to aid, there's a slot in the knobs to help prying open the plastic locking levers.
Do NOT try to remove in cool/ cold weather. Only when it's warm.
***Under construction***
Timo_90xj is offline
post #5 of 6 Old 02-16-2019, 07:57 PM Thread Starter
wilet-moeracing
1979 FSJ Cherokee
I saw that, and, for Arizona anyways it was cold, broke the rear one and stopped. I will try again on the other side and see if I can put this back together tomorrow, Thanks, for the help, Tim
post #6 of 6 Old 02-17-2019, 07:38 PM
GA05SPORT
1975 CJ5
They pull off.
Use a pair of needle nose pliers between the knob and the plastic slider.
Just lived this pain this weekend recovering my headliner, console and sun visors.
Had to go to the local Pull-A-Part this morning to replace the front slider assemblies.
GA05SPORT is offline
OE seats leave a lot to be desired, I just replaced mine with Suspension Seats Jerry Bransford TJ Wrangler Technical Forum 50 09-24-2018 02:47 PM
YJ Rear Seat Relocation for tall passengers natewill18 YJ Wrangler Technical Forum 3 03-13-2018 11:17 AM
Ranger Bench Front Seat Swap Writeup Awesome YJ Wrangler Technical Forum 6 03-11-2018 03:27 PM
How to- WJ Driver Side Outer Seat Bolster Reinforcement srmitchell WJ Grand Cherokee Forum 3 02-23-2018 09:35 PM
89 YJ seat belt replacement jjbradl1 YJ Wrangler Technical Forum 5 12-27-2017 12:23 PM
