96 ZJ will not idle HELP PLEASE - JeepForum.com
post #1 of 10 Old 07-14-2010, 03:38 PM Thread Starter
codykeon18
2005 WK
Ok so I have a 96 zj with a 5.2. I drove it two days ago with no problems. I went to leave today and it will not idle on its own. I have to give it gas and stay on the gas for it to stay running. Ive never had any problems with it starting or idling before. Anyone help me out or point in the right directon??
Thanks alot in advance,
Cody
codykeon18 is offline
post #2 of 10 Old 07-14-2010, 03:40 PM
g4x4xgeoff
g4x4xgeoff's Avatar
check to make sure your fuel supply isn't blocked anywhere.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #3 of 10 Old 07-14-2010, 03:43 PM Thread Starter
codykeon18
2005 WK
That was my firtst thought but shouldnt it have a problem running while im on the gas. (it doesnt)
post #4 of 10 Old 07-14-2010, 03:55 PM
freakinheep89
freakinheep89's Avatar
have you checked the IAC?
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #5 of 10 Old 07-14-2010, 04:31 PM Thread Starter
codykeon18
2005 WK
no i havent. But iM headied to the shop to check it out and clean the iac. Ill let you guys know how it works.
Thanks for the info!!
post #6 of 10 Old 07-14-2010, 04:39 PM Thread Starter
codykeon18
2005 WK
Ok so I just went outside to pull the ZJ in the shop and it started right up and idles fine. I didnt do anything to it and an hour ago it wouldnt idle at all???? Im confused
post #7 of 10 Old 07-14-2010, 05:03 PM
newfieZJ
newfieZJ's Avatar
clean it up anyways . test the TPS too .
could be a sign of something to come , perhaps a fuel pump , or something else . Test what you can now and try to find an issue before it leaves you stranded .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #8 of 10 Old 07-15-2010, 08:22 PM
bcollier1823
After cleaning up the IAC and throttle body you may try a tuneup to. Cap, rotor, plugs, wires
Billy Collier
bcollier1823 is offline
post #9 of 10 Old 07-16-2010, 07:28 PM
mr_user
Also make sure that your battery and alternator are in good shape. If either of those components are bad the idling is affected. In particular, if you've disconnected the battery recently or if it was drained the Jeep needs to "re-learn" it's idle.
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #10 of 10 Old 07-16-2010, 10:49 PM Thread Starter
codykeon18
2005 WK
That explains it. Thank you!! My battery is junk and was dead before it did this. By the way its running great now!!!! Thanks alot for the great info once again
Irratic Idle, intermetent irratic idle?? theycallmefudd ZJ Grand Cherokee Forum 1 07-12-2010 09:09 AM
ZJ 5.9L gets hot at idle Eric326 ZJ Grand Cherokee Forum 11 03-18-2010 07:58 PM
Rough Idle/High Idle/Weird Shifting FIXED!! UKFan4Sure! ZJ Grand Cherokee Forum 5 04-28-2007 07:43 AM
Idle Jumps High After Sitting at Idle gunthagunth ZJ Grand Cherokee Forum 0 09-21-2006 08:58 PM
is this a low idle? Saleen4971 ZJ Grand Cherokee Forum 0 02-11-2004 05:16 PM
