96 non flip glass lift gate on 98? - JeepForum.com
post #1 of 13 Old 06-29-2016, 05:36 AM Thread Starter
jswerve
I found a great lift gate (mine is rusted and dented and needs replaced) on a 96 ZJ. Unfortunately, it does not have the flip up glass I guess it was an option in 96 and not standard.
So, what would it take to make this work on my 98 5.9? I never really cared about the glass, rarely every used it. Everything else should bolt right up and be plug and play?
1998 5.9 |3.5" IRO lift w/adj CA and track bars | Bilstein 5100 | TJ Rubi wheels 245/75/16
jswerve is offline
post #2 of 13 Old 06-29-2016, 06:36 AM
vlackattack
It will physically bolt in, I think all the electronics will be the same, except the new liftgate won't have anything for the glass (obviously).
vlackattack is offline
post #3 of 13 Old 06-29-2016, 06:37 AM Thread Starter
jswerve
Meaning the switch to unlock the glass won't work which in this case doesn't matter.
Hmmm. Decisions!
Sent from my SM-G900R4 using Tapatalk
jswerve is offline
post #4 of 13 Old 06-29-2016, 06:48 AM
BorderWalker
As someone who also has to replace their liftgate but wants a lift glass version, count yourself lucky. I'll likely have to replace alot of wiring. You'll be plug and play.
._________.ooooo.
/ŻŻŻ|ŻŻ|ŻŻ\ŻŻŻŻŻ\,____
L/ŻŻ\\__|__|"/ŻŻŻ\=llllll=\
_(Ż))===)).....(Ż))===))Ż
BorderWalker is offline
post #5 of 13 Old 06-29-2016, 06:49 AM Thread Starter
jswerve
Yes if I were going old to new vs new to old it would be difficult
jswerve is offline
post #6 of 13 Old 06-29-2016, 03:24 PM
kg6mov
Hears the voices
kg6mov's Avatar
95 should be plug and play for flipper glass.
There are no added wires going between the body and the gate for flip vs fixed, it's only wiring inside the hatch that matters.
kg6mov is online now
post #7 of 13 Old 06-29-2016, 03:26 PM Thread Starter
jswerve
Must be when they went to obdII?
jswerve is offline
post #8 of 13 Old 06-29-2016, 03:28 PM
kg6mov
Hears the voices
kg6mov's Avatar
No, has nothing to do with OBD, it was a special thing in 95 that came with the orvis (and only the orvis AFAIK) and then became more common as time went on.
post #9 of 13 Old 06-29-2016, 04:29 PM Thread Starter
jswerve
Ok. Thanks. I think I'm gonna grab this lift gate and convert backwards
jswerve is offline
post #10 of 13 Old 06-29-2016, 06:40 PM Thread Starter
jswerve
Do you know if the non flip glass gates have rear defrost in the glass?
jswerve is offline
post #11 of 13 Old 06-29-2016, 11:20 PM
JonMopar
So you're going from a flipper to fix glass?? Not to but in but if your flipper mechanism works still, care to give it a new home?? (Mine doesnt work and my defroster became unsoldered)
JonMopar is offline
post #12 of 13 Old 06-30-2016, 11:23 AM
kg6mov
Hears the voices
kg6mov's Avatar
Both glass types have rear defrost.
post #13 of 13 Old 06-30-2016, 01:03 PM Thread Starter
jswerve
Thanks. You are a great resource to the Jeep community.
Can't see any reason not to snatch this thing up if it's in as good of shape as he claims.
jswerve is offline
